Thread Number: 89424
Can I get some help identify a whirlpool washer dryer please |
Post# 1140299 , Reply# 1   1/25/2022 at 08:19 (815 days old) by DADoES (TX, U.S. of A.)   |   | |
Nice find! They look to be in good condition. Dryer model/serial tag (pic 1) indicates 1969 model-year (T in model number), factory production in the 35th(?) week (pic not clear) of 1968. Timed drying. The "regular" cycle with Light, Med, Heavy, and Ex Heavy choices is timed, not moisture-sensing ... labeled that way for the convenience of selection via load/fabric weight instead of deciding how many minutes to run. That cycle has a 5-min cool down before turning off. Perm Press has 10 minutes of cooling. The Tumble Press setting runs a few mins of heat to tumble-"iron" items wrinkled from wear or packing. High temp is probably 155°F, med temp 145°F or maybe 135°F. The mechanical design of the dryer is still produced today. The washer's model/serial tag probably is on back of it. An old-style, belt-drive model, they were in production from the 1950s to 1986. It's a nicely-featured model toward the upper end of the lower-range models. Two speeds, perm press cycle, full choice of 5 temp combos, but only two water levels. Perm Press has a cool-down process after the wash (that's why the Rinse section is longer) ... partially drains, refills (use a Cold-rinse temp selection), agitates two mins, repeats those steps a 2nd time, then proceeds into the first spin, agitated rinse, and final spin. |
Post# 1140304 , Reply# 2   1/25/2022 at 08:58 (815 days old) by Frigidaireguy (Wiston-Salem, NC)   |   | |
My mother had this washer bought in the Summer of 1969. Great overall washer - I have this dryer now. Bob |
Post# 1140305 , Reply# 3   1/25/2022 at 09:11 (815 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1140306 , Reply# 4   1/25/2022 at 09:22 (815 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1140308 , Reply# 5   1/25/2022 at 09:47 (815 days old) by Spartin117 (Texas)   |   | |
Thank you so much for all the info! You answered everything for me :) |
Post# 1140315 , Reply# 6   1/25/2022 at 10:19 (815 days old) by Spartin117 (Texas)   |   | |
Found these on the back of the washer. |
Post# 1140317 , Reply# 7   1/25/2022 at 10:40 (815 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1140340 , Reply# 8   1/25/2022 at 15:57 (815 days old) by Maytag85 (Sean A806)   |   | |
Post# 1140380 , Reply# 9   1/25/2022 at 22:31 (815 days old) by eurekastar (Amarillo, Texas)   |   | |
