Thread Number: 89460
What is wrong with this BD Kenmore? |
Post# 1140616   1/29/2022 at 04:41 (811 days old) by chetlaham (United States)   |   | |
Post# 1140619 , Reply# 1   1/29/2022 at 06:31 (811 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1140627 , Reply# 2   1/29/2022 at 08:25 (811 days old) by chetlaham (United States)   |   | |
Post# 1140628 , Reply# 3   1/29/2022 at 08:39 (811 days old) by DADoES (TX, U.S. of A.)   |   | |
A common (but not only) cause is water in the transmission from a leaking centerpost bearing seal rusts the spring. The video is 1.5 years ago. Kirk wouldn't fix a belt-drive of that age either for the customer or to sell it. It's long-gone unless a collector saw the video when it livestreamed and went after him to get it. |
Post# 1140635 , Reply# 4   1/29/2022 at 11:54 (811 days old) by Maytag85 (Sean A806)   |   | |
That’s a weak or broken spring that’s causing that issue and DADoES explained all the probable causes for the spring to break. A lot of belt drives built from 1978 to 1986 had a tendency to leak down the center post since it was shortened and often times it would make it’s way down to the transmission contaminating the oil and causing the spring to corrode and break. The older belt drives didn’t really have that problem since they had the tall center post and the springs on the older belt drives really only went out since they were plain wore out from many cycles.
Post# 1140648 , Reply# 5   1/29/2022 at 13:55 (811 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1140665 , Reply# 6   1/29/2022 at 23:26 (811 days old) by chetlaham (United States)   |   | |
Post# 1140666 , Reply# 7   1/29/2022 at 23:27 (811 days old) by chetlaham (United States)   |   | |
Post# 1140669 , Reply# 8   1/30/2022 at 01:26 (811 days old) by Maytag85 (Sean A806)   |   | |
Post# 1140670 , Reply# 9   1/30/2022 at 02:11 (811 days old) by chetlaham (United States)   |   | |
Post# 1140688 , Reply# 10   1/30/2022 at 09:32 (810 days old) by DADoES (TX, U.S. of A.)   |   | |
I recall mention from someone (Combo52?) that the shorter centerpost, shorter spin tube, and shorter basket neck reduced the angular forces on the bearings which reduced wear on them. Placing the centerpost seals below the waterline may have been a side-issue. And just to say, water in the transmission could occur before the centerpost was shortened. |
Post# 1140715 , Reply# 11   1/30/2022 at 16:10 (810 days old) by Maytag85 (Sean A806)   |   | |
I think shortening the center post reduced the angular forces on the bearings as DADoES mentioned but didn’t really help the machines last longer. Whirlpool would have been better off if they redesigned the center post to use roller or ball type bearings and that definitely would have helped the machines last longer but when you are a greedy corporation, you really don’t care about how long a machine lasts as long as people keep on buying machines from you.
