Thread Number: 89525
Maytag Stop Ring |
Post# 1141326   2/5/2022 at 17:29 (804 days old) by scrubflex (bronx, new york)   |   | |
Is it possible to remove to the stop ring and reuse it without damaging it? |
Post# 1141329 , Reply# 1   2/5/2022 at 17:39 (804 days old) by qsd-dan (West)   |   | |
Post# 1141334 , Reply# 2   2/5/2022 at 18:09 (804 days old) by scrubflex (bronx, new york)   |   | |
Lghh!!! Okay thanks Dan |
Post# 1141510 , Reply# 3   2/7/2022 at 08:58 (802 days old) by scrubflex (bronx, new york)   |   | |
So, the stop ring can only be used with Power-fin agitator? |
Post# 1141526 , Reply# 4   2/7/2022 at 12:20 (802 days old) by qsd-dan (West)   |   | |
The stop ring was originally intended for EJN wringers beginning in 1939 and was used up until Nov 22, 1983. It was used in automatics from its inception until Maytag started using the 1/4" side mounted screw in the mid 80's although you can still install a stop ring up until around the mid 1990's when Maytag stopped cutting a groove for it in the agitator shaft on the orbital models. That little stop ring had a 50+ year run. |
Post# 1141535 , Reply# 5   2/7/2022 at 12:43 (802 days old) by scrubflex (bronx, new york)   |   | |
Then I'll have to remove it in order to use the PowerFlex 12 agitator. This agitator has FANTASTIC turnover with the long-stroke Dependable Drive transmission. |
Post# 1141749 , Reply# 6   2/9/2022 at 12:55 (800 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Your power flex 12 agitator has the stainless steel locking screw in it so you don’t need the rubber ring.
The load sensor agitator is far more effective in the orbital transmission washers. I always throw these non-load sensor ones away. My business partner Jason just bought a house with a very lightly used pair of 1992 Maytags in it, he couldn’t believe the difference when he took that agitator out and put the load sensor agitator in the washer. The matching stream of heat dryer is also is always a disappointment it’s slow and has poor airflow. He said they do work he’s going to use them until he gets his better machines in the house he’s remodeling the laundry room now. John L |
