Thread Number: 89651
Faster fills for Maytag Dependable washer |
Post# 1142553   2/19/2022 at 01:05 (789 days old) by scrubflex (bronx, new york)   |   | |
Is there a water inlet valve that can be used in Maytag washers for faster filling times? |
Post# 1142562 , Reply# 1   2/19/2022 at 05:12 (789 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You can either drill or take out the flow washer restriction in the MT valve or you can install a WP BD inlet valve, Pt # 358277 and it will really fill fast.
Having this valve in WP BD machines is why they did such a good spray rinsing [ and rinsing overall ], it might cause a MT to water-lock when it is doing s SR however, you would have to experiment.
That WP valve I mentioned when set for warm water fills at a rate of around 9 gallons per minute, almost 3 times faster than the original MT valve.
Post# 1142583 , Reply# 2   2/19/2022 at 12:17 (788 days old) by scrubflex (bronx, new york)   |   | |
Hey John L, I brought that one but, the hose seems to be too small for the valve nozzle. I didn't want to force it and damage the hose opening. What I'm I missing? |
Post# 1142585 , Reply# 3   2/19/2022 at 12:31 (788 days old) by RP2813 (Sannazay)   |   | |
Post# 1142594 , Reply# 4   2/19/2022 at 14:54 (788 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
1/2"valve outlet, you can force the smaller 3/8" Maytag hose on the larger nipple, put the end of the hose in a mug of boiling water that you heated in a MWO just before you install it, You may not even need a hose clamp, I have done this at least 100 times over the years on various washers.
You may also have to bend the coil terminals slightly so they do not short on the inside of the cabinet as well. |
Post# 1142598 , Reply# 5   2/19/2022 at 15:10 (788 days old) by scrubflex (bronx, new york)   |   | |
Awesome, thanks John L, just needed confirmation that it's possible and I did not waste money. |
