Thread Number: 89672
Looking for Horton valve CO2086-4 N3042 10W |
Post# 1142756 , Reply# 1   2/21/2022 at 19:13 (787 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 1143044 , Reply# 2   2/24/2022 at 19:07 (784 days old) by helderman (Pearland, Texas)   |   | |
It is a 1962 Frigidaire Model WCDAS |
Post# 1143045 , Reply# 3   2/24/2022 at 19:40 (784 days old) by helderman (Pearland, Texas)   |   | |
here are some pics @swestoyz |
Post# 1143049 , Reply# 4   2/24/2022 at 21:00 (784 days old) by swestoyz (Cedar Falls, IA)   |   | |
So, thankfully you're looking to replace the water valve on a 1-18 Frigidaire, rather than an earlier solid tub Frigidaire with a metered timed fill. Finding replacement valves for a metered time fill Frigidaire is a bit tricky. 1-18's regulate based on the pressure switch so the rate of fill isn't as critical. Frigidaire valves also use a flange mount rather than a long style mount (these are my descriptors, not sure if these terms are widely used).
There are several out on ebay that would work for you. This is just one of many (it would require the solenoids to be swapped from the old to the new).
Good luck!
Ben
https://www.ebay.com/itm/304288553930QUE...
