Thread Number: 89679
DOA Speed Queen Pump |
Post# 1142813   2/22/2022 at 12:42 (791 days old) by panthera (Rocky Mountains)   |   | |
With everyone's help here - and thank you! - I got the belts for the Speed Queen.
The pump died. I knew it was going which is why I didn't want to touch it, but really? It died just as I was spinning to make sure there was as little water as possible.... Sheesh. So, given that the pumps are unobtanium, looks like this is hitting the road. Sigh. Have to check with Modern-Hygiene first, but we may have some parts to donate to those who might need them. He'll let me know this evening. Bummer! (Though this does give us room for the 1961 GE Filter-Flo and she's PANK!!!!!!!) |
Post# 1142818 , Reply# 1   2/22/2022 at 13:13 (791 days old) by turquoisedude (.)   |   | |
Post# 1142874 , Reply# 2   2/22/2022 at 21:02 (790 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1142882 , Reply# 3   2/22/2022 at 22:10 (790 days old) by panthera (Rocky Mountains)   |   | |
Here's the plate on it. I'll try to get a close up of the pump, tomorrow.
Post# 1142883 , Reply# 4   2/22/2022 at 22:12 (790 days old) by panthera (Rocky Mountains)   |   | |
Post# 1142886 , Reply# 5   2/22/2022 at 22:47 (790 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1142891 , Reply# 6   2/22/2022 at 23:44 (790 days old) by swestoyz (Cedar Falls, IA)   |   | |
There are a handful on ebay. One way to tell the earlier solenoid drive pump from the later reversing is the width of the center section of the pulley. If it is wide the pulley is for use with a 3L profile belt (reversing motor), if narrow rhen for use with the wider 4L belt (solenoid drive). There are some variations of Speed Queens that do require a special version of this pump (some suds saver models but not all). For yours this pump should work fine.
It's tricky as sellers often times don't have the full assembly PN and throw the main body casting or bottom plate PN on the auction.
https://www.ebay.com/itm/263469296563QUE...
Ben |
Post# 1142974 , Reply# 7   2/23/2022 at 23:03 (789 days old) by panthera (Rocky Mountains)   |   | |
Post# 1142975 , Reply# 8   2/23/2022 at 23:05 (789 days old) by panthera (Rocky Mountains)   |   | |
Post# 1143003 , Reply# 9   2/24/2022 at 09:11 (789 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1143063 , Reply# 10   2/24/2022 at 23:23 (788 days old) by Hippiedoll ( arizona )   |   | |
Post# 1143377 , Reply# 11   2/28/2022 at 06:32 (785 days old) by Oldwasherguy (Ladson SC)   |   | |
