Thread Number: 89694
Whirlpool 2290 Washer 1979, Lid Switch Question |
Post# 1142993 , Reply# 1   2/24/2022 at 06:55 (790 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
From your pictures the location of the lid switch is not obvious but it’s probably attached to the hinges in some way.
If you raise the top of the machine you’ll probably see wiring attached to it if you can’t easily correct the problem by adjusting it or replacing a part you may consider bypassing it so the washer with spin with the lid open or closed. |
Post# 1142997 , Reply# 3   2/24/2022 at 07:23 (790 days old) by DADoES (TX, U.S. of A.)   |   | |
