Thread Number: 89721
Stripped hex head screw |
Post# 1143263   2/27/2022 at 04:13 (787 days old) by scrubflex (bronx, new york)   |   | |
Is it possible to restore a stripped or worn-out 'HEX HEAD with FLANGE' screw? |
Post# 1143310 , Reply# 2   2/27/2022 at 13:25 (787 days old) by robbinsandmyers (Conn)   |   | |
Post# 1143311 , Reply# 3   2/27/2022 at 13:26 (787 days old) by robbinsandmyers (Conn)   |   | |
Another option. You may have to buy a box though. I second checking out your local hardware store for them. The older the store the better.
CLICK HERE TO GO TO robbinsandmyers's LINK |
Post# 1143403 , Reply# 6   2/28/2022 at 13:38 (786 days old) by robbinsandmyers (Conn)   |   | |
Post# 1143461 , Reply# 8   3/1/2022 at 05:58 (785 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These are very commonly used in plastic for their good grip.
The screw is very unlikely to strip, the plastic even in the new agitator can strip very easily, it just takes one little turn too far and it will strip if the screw is not gripping into the agitator you need a larger screw, you could also get one of the rubber lockrings and put it on the shaft and that’ll hold the agitator in place fairly well. John L |
Post# 1143477 , Reply# 10   3/1/2022 at 12:08 (785 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1143498 , Reply# 11   3/1/2022 at 15:04 (785 days old) by scrubflex (bronx, new york)   |   | |
Okay then...excellent, problem solved! |
