Thread Number: 89733
Maytag A9600 |
Post# 1143418 , Reply# 1   2/28/2022 at 16:50 (786 days old) by qsd-dan (West)   |   | |
It's hard to diagnose the noise without a video. If you can upload a clip on youtube or another platform, it would greatly help.
Only the tub bearing and radial bearing in the brake package are operational during the spin cycle. Make sure you're not misdiagnosing the noise over worn damper pads.
When you replaced the tub bearing, did you install a new stem and boot seal or reuse the old one?
If the noise sounds like this, it's a failed tub bearing.
Post# 1143423 , Reply# 2   2/28/2022 at 18:48 (786 days old) by monicam (Canada)   |   | |
vimeo.com/683078831... Here is video of my noisy Maytag A9600 during the spin cycle CLICK HERE TO GO TO monicam's LINK |
Post# 1143431 , Reply# 3   2/28/2022 at 19:51 (786 days old) by monicam (Canada)   |   | |
I did replace with a new stem and boot seal when the tub bearing was replaced a year ago |
Post# 1143435 , Reply# 4   2/28/2022 at 20:31 (786 days old) by qsd-dan (West)   |   | |
Post# 1143440 , Reply# 5   2/28/2022 at 21:12 (786 days old) by monicam (Canada)   |   | |
Thank you very much for the diagnosis! I appreciate your help very much. I will let you know how the repair/replacement goes after I obtain the correct part and install it. 🙂 |
Post# 1144297 , Reply# 7   3/11/2022 at 12:24 (776 days old) by Hippiedoll ( arizona )   |   | |
