Thread Number: 89748
/ Tag: Vintage Dryers
Westinghouse D-6 220v plug configuration |
Post# 1143613   3/3/2022 at 11:30 (783 days old) by Marks (Tucker, GA)   |   | |
Hi Everyone,
I want to run the dryer on 220v but it is currently set up for 110v. I know there’s some wire switching here but I want to be very sure before I attempt anything. How do I have to set the block up and where do the 3 incoming wires attach?
Post# 1143615 , Reply# 1   3/3/2022 at 11:51 (783 days old) by turquoisedude (.)   |   | |
Mark, I'm just about to leave on vacay for about 10 days, but I'm pretty sure that you have to disconnect the yellow wire from the white terminal and re-install it on the 'empty' post. You would then wire a 240v supply cord with its red, white, and black wires connected to the corresponding ones on the terminal block. If you don't get a more definitive answer, I'll take a picture of my CD-6 wiring block and send it to you when I get back on March 15th.
Post# 1143616 , Reply# 2   3/3/2022 at 11:53 (783 days old) by marks (Tucker, GA)   |   | |
Post# 1143629 , Reply# 3   3/3/2022 at 14:24 (783 days old) by marks (Tucker, GA)   |   | |
Post# 1143630 , Reply# 4   3/3/2022 at 14:25 (783 days old) by appnut (TX)   |   | |
