Thread Number: 89763
/ Tag: Vintage Dishwashers
Kitchenaid Imperial 21 starts and stops |
Post# 1143818 , Reply# 1   3/6/2022 at 07:27 (753 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1143838 , Reply# 3   3/6/2022 at 10:58 (753 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 1143854 , Reply# 4   3/6/2022 at 11:45 (753 days old) by eronie (Flushing Michigan)   |   | |
Bad start relay. |
Post# 1143855 , Reply# 5   3/6/2022 at 11:46 (753 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The motor start relay may be sticking that’s the first thing to check.
Other than that the motor has a shorted winding and will need to be replaced. There is an overload protector built into the motor that’s probably what is cycling it off after 15 seconds, this problem has nothing to do with the timer etc. Remove the lower panel check carefully for any signs of past water leaking into the motor or on the relay, if water has been getting on either one of these parts that could’ve been the cause of the problem. John |
Post# 1143881 , Reply# 6   3/6/2022 at 16:21 (753 days old) by KajunKenny (Louisiana )   |   | |
Is this the motor start relay
Post# 1143885 , Reply# 7   3/6/2022 at 17:12 (753 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
