Thread Number: 89790
/ Tag: Vintage Dishwashers
Dishwasher panel |
Post# 1144128   3/9/2022 at 10:35 (749 days old) by floyde (Los Angeles, CA)   |   | |
If I remove this panel to install the magnetic panel what is under the black panel? Is it metal or what? Thanks . |
Post# 1144152 , Reply# 1   3/9/2022 at 13:54 (749 days old) by quincyman (Oldsmar, FL)   |   | |
Why would you do that to such a classic machine??? |
Post# 1144169 , Reply# 2   3/9/2022 at 17:51 (749 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1144199 , Reply# 3   3/9/2022 at 23:23 (749 days old) by askolover (South of Nash Vegas, TN)   |   | |
I'm pretty sure it's a magnetic panel like this. It just sticks on the front of the dishwasher...but it won't stick to aluminum.
CLICK HERE TO GO TO askolover's LINK |
Post# 1144210 , Reply# 4   3/10/2022 at 06:10 (748 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You would be able to install this on your older KitchenAid dishwasher, there are two removable aluminum panels with a piece of corrugated cardboard as a spacer that are easily removed with a magnetic galvanize steel panel behind that.
The problem may be that this new panel is not thick enough to properly space itself into the trim on your dishwasher your dishwasher is designed for panels that are 1/4 inch thick. You might want to glue this new magnetic panel to one of your removable panels you will also have to cut this new panel because your dishwasher has a two piece front panel but you could make it work it would look cool . John L |
Post# 1144215 , Reply# 5   3/10/2022 at 07:23 (748 days old) by quincyman (Oldsmar, FL)   |   | |
...he was going to remove the control panel and I couldn't understand how. I guess if you like that look, go for it. |
