Thread Number: 89796
/ Tag: Wanted to Buy Items
early 70s Maytag washer / dryer pair |
Post# 1144224 , Reply# 1   3/10/2022 at 09:10 (775 days old) by qsd-dan (West)   |   | |
The washer is BOL....probably an A106 or A107. Small capacity tub. Date would be somewhere between late 1972-1974, possibly very early '75.
Can't tell what the dryer is without a peek at the timer dial but it's probably a 308 or 408. Date for this would be 1976-early 1980.
As far as price, I'd say $50-$75.
These can be resurrected fairly easy but I wouldn't pour a ton of money into BOL machines. Just do the minimum to get them working well and run 'em.
Post# 1144237 , Reply# 2   3/10/2022 at 13:00 (775 days old) by RP2813 (Sannazay)   |   | |
Ah, let me guess. The pictures were taken with an iPhone. Grrrrr.
Given your location, outdoor laundry facilities are often the norm. Those machines may only look bad on the outside. Dan has provided his uber-expert advice. If you're going to use them for daily drivers, don't expect something like a full size or larger comforter to fit in the washer. The dryer appears to be late enough to maybe have a larger drum, and if so, it would be worth keeping if you should upgrade to a large tub, two-speed Maytag washer in the future. |
Post# 1144255 , Reply# 3   3/10/2022 at 16:31 (775 days old) by gregingotham (New York)   |   | |
personally i like the center-dial models. That to me says "classic Maytag".....the rest look like they were trying to be more like other brands. |
Post# 1144263 , Reply# 4   3/10/2022 at 18:12 (775 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The Maytag washer in your picture and maybe the dryer to have been sitting outside for at least 5 to 10 years maybe longer.
I don’t think I would take them for anything more than free the chance of being able to revive them is fairly small without a lot of work even the belts will be rusted to the pulleys the motor pulley will be ruined in the dryer from the moisture. Rollers will be seized in the dryer idler pulley will be seized etc. I can’t believe someone’s even trying to sell something that old and that dirty. You’ll be much better off finding someone selling something that still at the somewhat working with may be only a minor known flaw or Two. John L |
Post# 1144353 , Reply# 5   3/12/2022 at 06:24 (773 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
Not sure if this site renders it properly but the photo beats a 2021 Nokia G20…
Post# 1144380 , Reply# 6   3/12/2022 at 14:11 (773 days old) by RP2813 (Sannazay)   |   | |
Callan, the improper reorienting of images seems to be associated with iPhones, and for whatever reason (I do not think it's browser-related), they render either sideways or upside down almost invariably when posted here. I think there's something lost in translation between Apple and "everybody else" but maybe not with older iPhone versions.
I wish they would fire the millennial who came up with whatever sort of "we know better" enhanced experience nonsense that created this problem. |
Post# 1144398 , Reply# 7   3/12/2022 at 18:19 (773 days old) by Smartdrive1100 (Melbourne, Victoria, Australia)   |   | |
I’ve posted photos on here from my iPhone before, but this time I posted it from my iPad (could be because of that, but it is unlikely)
It has to do with the website as this site predates smartphones and is running on a Linux or windows server that doesn’t support iPhones, or it could be that the photo I uploaded was 4K. either way it hasn’t got to do with iPhones, just the way that the program processes the photo that was taken by an iPhone. I am not having a go at this website, just trying to explain what I think is happening. |
Post# 1144409 , Reply# 8   3/12/2022 at 21:24 (772 days old) by DADoES (TX, U.S. of A.)   |   | |
IIRC, Robert made a change site code for photo handling in an attempt to interpret data-flags in image files and correct for mis-oriented pictures, but the correction isn't always successful. A way to handle it is pull the pics out of your phone to a computer with photo editing software, rotate them to proper orientation and save as a new file if necessary for the change to stick. I suppose it's possible some newer photo editing software recognizes and retains the original orientation. I use Paint Shop Pro 7 which is always able to fix the orientation. |
Post# 1144459 , Reply# 10   3/13/2022 at 14:25 (772 days old) by RP2813 (Sannazay)   |   | |
Any picture I post that I took with my phone goes through the process of saving to my laptop and using editing software, but the editing happens after posting here because the picture is properly oriented in my files, but gets disoriented when included in a post. That's when the aggravation begins because I can edit and rotate in three different directions to no avail. |
