Thread Number: 89831
/ Tag: Vintage Dryers
Mom's old Maytag Dryer Problems |
Post# 1144595 , Reply# 1   3/15/2022 at 18:01 (771 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There are no thermal fuses in this dryer, maybe you’ll be lucky and the plug just worked its way out of the socket or the circuit breaker or fuse has tripped.
Other than that you’re gonna have to have some hand tools and be good with diagnosing electrical stuff you’ll need an volt ohm meter to be begin to figure out why one of these dryers won’t run. Take a look when you visit and see what you can figure out we can try to answer questions, likely reasons it won’t run for a bad selector switch possible bad door switch possible bad motor broken or burned wire on the terminal block or cord are the most likely things. Good luck with it John |
