Thread Number: 90017
/ Tag: Vintage Dryers
Testing the heater system in a natural gas dryer ? |
Post# 1146089 , Reply# 1   4/8/2022 at 21:32 (742 days old) by qsd-dan (West)   |   | |
Post# 1146105 , Reply# 2   4/9/2022 at 06:49 (741 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It would be more helpful to have a model number I could give more Pacific advice.
You can run the dryer mechanically and see how it sounds, when you select from air fluff to heat you should hear a click from the solenoid on the gas valve.
As Dan mentioned if it’s a model you can take the lower panel off of you should see a glow from the igniter it should come on for about a minute and then shut off that would show you that the igniter and the flame sensor working, other than that you really need to connect it to gas.
You can also make sure the timer works by setting it on a time dry cycle.
John L |
