Thread Number: 90468
Spin Agitate issues |
Post# 1150467 , Reply# 1   6/7/2022 at 02:23 (688 days old) by Bazzybtec (Churchill Queensland Australia)   |   | |
I have taken a video of what it does. Excuse how dirty it is and the lack of lid. it has broken hinges and i intend to replace them when i get it working. CLICK HERE TO GO TO Bazzybtec's LINK |
Post# 1150476 , Reply# 2   6/7/2022 at 10:01 (688 days old) by Maytag85 (Sean A806)   |   | |
The clutch looks like it needs to be adjusted, not sure what’s causing the other issue with the agitator shaft being locked up. More than likely locked up to the spin tube, only way I can think about fixing that is to remove the transmission and remove the spin tube off of the agitator shaft if it’s possible and put some grease in the spin tube and put a little on the spin tube itself to be sure it won’t lock up or do anything peculiar.
Post# 1150534 , Reply# 5   6/8/2022 at 01:11 (687 days old) by Maytag85 (Sean A806)   |   | |
Post# 1150558 , Reply# 6   6/8/2022 at 09:35 (687 days old) by Unimatic1140 (Minneapolis)   |   | |
That doesn't look like just a clutch issue, it does appear as Chris said that agitator shaft is frozen inside the spin shaft. The wash basket seems to rotate back and forth with the agitator which isn't suppose to happen. The entire transmission is going to need to be pulled out of the machine and the spin tube assembly will need to be removed and lubricated on the inside at minimum.
