Thread Number: 90506
/ Tag: Wanted to Buy Items
Wanted: Maytag 808 control panel |
Post# 1150357   6/5/2022 at 19:31 (662 days old) by Maytag85 (Sean A806)   |   | |
Looking for a Maytag 808 control panel since I am in the process of bringing back a Maytag DE306 that’s been sitting for several years. Essentially converting it into an 806 dryer with auto dry timer and temperature selections to allow for a bit more options and flexibility. Will be a customized 806 dryer that (hopefully) will go with an Maytag A806 when I find one or one locally pops up for sale in my area. Not in any great rush to find one since restorations/refurbishment takes some time but would like to find an Maytag 808 dryer control panel eventually.
Post# 1160924 , Reply# 1   10/2/2022 at 16:56 (543 days old) by Maytag85 (Sean A806)   |   | |
Post# 1162239 , Reply# 2   10/22/2022 at 09:26 (524 days old) by 63kenmore (Burlington, North Carolina)   |   | |
I’m not sure what an 808 panel should look like, but I have the top consoles to a harvest gold Maytag washer and dryer from the 70’s. We saved them when the washer developed a leak in the tub that could not be fixed. Can you post a picture of what you want? |
Post# 1162243 , Reply# 3   10/22/2022 at 09:46 (524 days old) by Maytag85 (Sean A806)   |   | |
Looks like a Maytag DE806 control panel, but has a opening for dryness and temperature selections. I may just end up putting a 806 console on the dryer I am putting together since there is a Maytag DE806 at that appliance junkyard in Glendale Arizona, along with putting a 40)/408 auto dry timer in as well with a low heat double throw switch thermostat if one does exist. Reason why I’d put a low heat thermostat in is I’ve had great results with the low heat cycling thermostat I installed on my Maytag DG306 back in 2020 since it was able to hold a more steady temperature that the 140F it had in it.
Post# 1162303 , Reply# 4   10/22/2022 at 23:33 (523 days old) by Maytag85 (Sean A806)   |   | |
Even though this is a Maytag 306 dryer console, this is basically what I need. There’s 4 screws you can remove to remove the console.
Post# 1162439 , Reply# 5   10/24/2022 at 18:53 (521 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1162446 , Reply# 6   10/24/2022 at 19:44 (521 days old) by Maytag85 (Sean A806)   |   | |
Hi John, I toyed around with doing that but don’t really want to end up knackering this Maytag console since it’s original to this Maytag dryer (at least the cabinet) and just want to preserve the original console since there aren’t many of these Maytag dryer console left out there from 1966 to 1980. Not in really any sort of big rush to get it back together and running since the Maytag A806 I picked up from waterwitch needs a cosmetic restoration done since I need to fill in a few chips on the porcelain top and give the cabinet a coat or so of paint and it’ll be done.
I believe there’s a Maytag DE408 dryer in that appliance junkyard in Glendale Arizona with the auto dry timer, will snatch that up since it has the auto dry timer and had the extra terminals on the timer for low and regular temperature selections since the DE407 are single temperature timers from what I’ve read in the archives. |
Post# 1162493 , Reply# 7   10/25/2022 at 17:17 (520 days old) by Maytag85 (Sean A806)   |   | |
Post# 1162820 , Reply# 8   10/29/2022 at 18:05 (516 days old) by Maytag85 (Sean A806)   |   | |
Post# 1165066 , Reply# 9   11/28/2022 at 10:56 (486 days old) by super32 (Blackstone Massachusetts)   |   | |
