Thread Number: 90598
Fabric softener dispenser. |
Post# 1151184   6/15/2022 at 06:50 (674 days old) by rpms (ontario canada)   |   | |
My mom's 29 year old Kenmore Dual Action has had the agitator dogs replaced twice.
The other day I noticed it was a bit sluggish turning but seem to right itself. I then noticed the fabric softener was not emptying . Even after the last spin it would be still full. I took it off and swirled it around and nothing came out. It is completely plugged. I turned it upside down and shook out the water. It was gross. Bits of wax or white fat the size of small kernels of corn started coming out. I soaked it in hot water and vinegar and the water will run out the bottom on one side. I know the roto swirl cups would come apart to clean but does the dual action come apart? I tried to twist it but nothing happened. What should I also try soaking it in? Oddly enuff, the agitator started washing with no problem. Could the weight of the full dispenser keep it from turning? |
Post# 1151185 , Reply# 1   6/15/2022 at 07:22 (674 days old) by BlockEight88 (Hobart, IN)   |   | |
Post# 1151202 , Reply# 2   6/15/2022 at 11:05 (674 days old) by DADoES (TX, U.S. of A.)   |   | |
