Thread Number: 90952
agitator shaft removal |
Post# 1154671 , Reply# 1   7/19/2022 at 10:42 (645 days old) by DADoES (TX, U.S. of A.)   |   | |
May be possible. Look at the photos in the service manual that you presumably received. The transmission cover would have to come off with the spin components atop it, bringing the agitator shaft along IF there's nothing else inside the transmission that would prevent it from coming out. Shafts of four internal components protrude through the transmission cover: the agitator shaft, the agitator shift fork (through which the agitator cam bar passes), the sector gear (onto which the wigwag mounts), and the main drive pinion (onto which the transmission pulley mounts). The transmission pulley, wigwag, and cam bar(s) would normally be removed first, which allows the related internal parts to remain inside the transmission base. Someone with more years of hands-on experience can confirm or deny or expand on any or all of this detail. |
