Does anyone happen to have a wiring diagram for a Miele w1926 washer? Or know if there’s one inside the washer somewhere? I’ve been working on the drain pump but I haven’t noticed a wiring diagram.
My particular model takes a 120v drain pump, which has been long discontinued. Mine has started leaking.
The Miele parts spec shows a 240v pump as an alternative but we need to change the wiring to change the voltage sent to the pump from 120 to 240.
The machine itself is 240v, this is the US model if that changes things.
