Yet another problem, now the detergent dispenser door will not open during cycle. Tried cleaning good with hot water to make sure no powder stuck in there. Opened manually and will open but doesn't spring open like it should when released. looked for part and found bimetal assembly but not sure if that is the problem. Does this little door have a spring somewhere that should open door or is bimetal assembly alone what opens it. Thank you, Pat
