Thread Number: 91089
basket drive pulley difference |
Post# 1155924 , Reply# 1   8/4/2022 at 05:10 (602 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This bronze T bearing is supposed to lift out of the bottom of the clutch assembly, but due to rust inside the tube it may be stuck.
If you put some penetrating oil down the The inside of the spin tube you may be able to take a vice grip pliers and work this bearing out of the spin tube, if it’s in bad condition you might need an additional part but you can probably reuse it by cleaning it up and lubricating it. John L |
