Thread Number: 91183
Fill level tubing |
Post# 1156897 , Reply# 1   8/14/2022 at 06:16 (593 days old) by Bazzybtec (Churchill Queensland Australia)   |   | |
Here are some pics of the unit and the pipe |
Post# 1156902 , Reply# 2   8/14/2022 at 09:29 (593 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1156910 , Reply# 3   8/14/2022 at 12:04 (592 days old) by qsd-dan (West)   |   | |
Post# 1156949 , Reply# 4   8/14/2022 at 19:32 (592 days old) by bazzybtec (Churchill Queensland Australia)   |   | |
its high because it was what i had on hand to test the machine. this is not where the machine will be used it will be put in the Garage properly along with 4 other machines when the garage is built. I cut the damaged bit off and it seems to fill properly now This post was last edited 08/14/2022 at 21:09 |
Post# 1157243 , Reply# 5   8/17/2022 at 22:24 (589 days old) by LowEfficiency (Iowa)   |   | |
Post# 1157246 , Reply# 6   8/17/2022 at 22:36 (589 days old) by washdaddy (Baltimore)   |   | |
Perhaps the machine had some work done to it and whoever did it used the same wire throughout the wiring process they did. I totally agree with you. It seems strange it would be wired that way |
Post# 1157270 , Reply# 8   8/18/2022 at 07:42 (589 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This was fairly common in the US as well early on.
Norge washers at all white wiring, early whirlpool belt washing machines at all white wiring but use blue or yellow just for the motor circuit. It’s a little more expensive to have many different color rolls of wiring around to make a hardest that’s all color coded by wire color. These earlier US machines also had little markings at the ends of each wire with numbers to tell you where they went. John L |
