Thread Number: 91287
Whirlpool rebuild completed |
Post# 1158004 , Reply# 3   8/27/2022 at 09:03 (579 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The funny noises is probably the agitator rattling on the basket center post it’s a pretty normal sound when there’s almost nothing in the washer with a load of clothing it probably will go away.
You could also have something to do with the snubber on the tub cover sometimes those make a little knocking noise or rubbing noise. Hopefully the new pump will quiet down the pump and you’ll have a nice usable machine. Because of the long heat up time to heat 16 gallons of water you definitely want to use it with the suds saver if you’re doing many hot washes. |
Post# 1158024 , Reply# 4   8/27/2022 at 18:25 (579 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
