Thread Number: 91347
/ Tag: Vintage Dishwashers
danby ddw496w dishwasher |
Post# 1158537   9/2/2022 at 22:07 (573 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
I think I got this in the right place since it is a vintage DW
I am wondering about the heating element I use the whole cycle it does not run in the rinse and hold part of the cycle it does run in the wash portion the long interval of the cycle I watched the dial and it clicks 2 times and then pauses while it heats then in the next section of the cycle it does not heat it clicked thru that portion of the cycle the next section I think it does not heat the last section I think it does heat as the water draining out was hotter than normal Hopefully someone here who has one can clarify it for me it had a mechanical dial and 2 push-buttons one for the power and one for the heater |
Post# 1158568 , Reply# 1   9/3/2022 at 10:50 (572 days old) by DADoES (TX, U.S. of A.)   |   | |
I have a Danby DDW396W. It operates as you describe. The Sani (heated) option heats the water to 158°F / 70°C. The cycle is delayed until a thermostat registers the target water temperature. Delay occurs in the wash period and possibly on the final rinse ... depends how the timer is designed for the specific model. Selecting Economy does not heat the water. Rinse-And-Hold is a quick rinse of a few dirty dishes to be held for a later full load. It purposely leaves the dishware wet so residual soil doesn't dry/bake-on. Heating the water higher than the incoming supply temperature isn't necessary, and would be counterproductive to the purpose of Rinse-And-Hold. |
Post# 1158924 , Reply# 2   9/6/2022 at 19:00 (569 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1159653 , Reply# 3   9/16/2022 at 14:24 (559 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1159951 , Reply# 4   9/19/2022 at 19:38 (556 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1160513 , Reply# 5   9/27/2022 at 18:06 (548 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1161776 , Reply# 6   10/15/2022 at 17:20 (530 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1171965 , Reply# 7   2/11/2023 at 18:42 (411 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
more observation
it heats up to 150 or what the set temp is pauses in the first wash to heat then advances I use the full cycle the 3 rinses I use so my good crate and barrel cusps and saucers get rinsed very well so they do not etch from the DW detergent In the 3 rinses it heats but does not pause the timer just advances but the heater is on all the time it runs in the 3 rinses I found out by accident as I left the sani button depressed for the whole cycle |
Post# 1172678 , Reply# 8   2/19/2023 at 15:47 (403 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1172748 , Reply# 9   2/20/2023 at 13:17 (402 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 1174677 , Reply# 10   3/14/2023 at 01:28 (381 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
