Thread Number: 91481
Adding sacrificial anode to suds pump? 1951 kenmore |
Post# 1160013 , Reply# 1   9/20/2022 at 17:50 (577 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1160056 , Reply# 3   9/21/2022 at 11:17 (576 days old) by swestoyz (Cedar Falls, IA)   |   | |
Can't say I've seen this done before. As an alternative, in attempts of preserving delicate parts, I've had recent success in coating/sealing delicate pot metal items that are in constant water contact, such as your suds pump.
Most recently I've used KBS RustSeal to coat the inside of a drain case housing, pump housings, and impeller, all made of pot metal. It's a bit finicky as it will flow to the lowest point while it dries. Multiple thin coats will help prevent pooling. Once dry, their claims of an almost ceramic coating is no joke. Attached photos are of a pot metal impeller pump w/ the KBS RustSeal applied. While the brush strokes are visible within the finish, it's totally smooth and water pools as it comes in contact with the coating, rather than the impeller absorbing water. The finish with KBS RustSeal also feels more substantial than POR-15, possibility indicating that the KBS stuff is quite different from POR-15. I'll leave it at that as I'm certainly far from an expert. www.kbs-coatings.com/rust... Congrats on the frog-eye set! Beauties! Ben |
Post# 1160066 , Reply# 4   9/21/2022 at 14:13 (576 days old) by Snail (Granite Falls, Washington)   |   | |
Hmm that looks pretty good. Yeah.. maybe I should consider coating it. I have some epoxy sealer I could use. I also have access to anodizing at work (just don't tell the boss) |
Post# 1160079 , Reply# 5   9/21/2022 at 19:26 (576 days old) by bradfordwhite (central U.S.)   |   | |
" I was thinking about making a zinc anode on the lathe and attaching it to the inside of the suds pump somewhere."
Won't that degrade and the metal bits end up in your laundry water and clothing? It be easier to buy a new/used plastic body washer pump for like $30 and replace it? CLICK HERE TO GO TO bradfordwhite's LINK on eBay
Post# 1160122 , Reply# 6   9/22/2022 at 07:27 (575 days old) by Slowspin66 (lincoln uk)   |   | |
. I’ve done a couple of methods in the past . A resin coating of all the parts that are made of the alloy metal after they have been cleaned up . As a belt and braces approach I’ve had the bits powder coated . It’s a really good process as the metal Is totally protected from water and there is no water damage again . The later however doesn’t retain the original appearance .. but it’s service free once done ..if there are holes in any of the castings I’ve used a commercial silicone to seal the holes once it’s powder coated . These are from a Bendix I’ve done in the past …
Post# 1160171 , Reply# 8   9/22/2022 at 22:18 (574 days old) by Slowspin66 (lincoln uk)   |   | |
Post# 1160254 , Reply# 9   9/23/2022 at 20:10 (574 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
