Thread Number: 91524
POD 9-26-2022 Easy Golden Regent Automatic Washer |
Post# 1160472   9/26/2022 at 21:00 (575 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Checked rating of Easy Automatic Washer in 1964 Annual Buying Guide for Consumer Reports and they did not have much good to say about the Easy Automatic Washer. I will check with John and Jeff about servicing reputation. |
Post# 1160968 , Reply# 1   10/2/2022 at 18:53 (570 days old) by lotsosudz (Sacramento, CA)   |   | |
Post# 1161018 , Reply# 2   10/2/2022 at 22:41 (569 days old) by DannyBoy (Texarkana)   |   | |
Please pardon my ignorance, but where does one find the Picture of the Day? |
Post# 1161027 , Reply# 3   10/3/2022 at 01:25 (569 days old) by Maytag85 (Sean A806)   |   | |
Post# 1161043 , Reply# 4   10/3/2022 at 11:47 (569 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1161085 , Reply# 6   10/3/2022 at 21:39 (568 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 1161123 , Reply# 7   10/4/2022 at 13:23 (568 days old) by Unimatic1140 (Minneapolis)   |   | |
Unfortunately the Velvapower had a terribly designed clutch for transmitting power to the spin shaft. It simply used a drive spring that was loosened when the motor turned counterclockwise for spin. This transmitted the motor torque in a very similar fashion that you see with "indexing" washer tubs. The result was it took nearly two full minutes for the tub to come up to full speed spin and with the final spin being only four minutes on all models that made for some really poor water extraction even at a 650rpm spin.
