Thread Number: 91565  /  Tag: Vintage Automatic Washers
Washer motor
Post# 1160870   10/1/2022 at 23:13 (562 days old) by Burned (Canada)
I have a 1998 GE Washer. The motor was working before, got hot and stopped. I took it apart and cleaned the contacts but now it hums. Is the capacitor inside the motor on this model? The motor is a GE model 5KH61KW2516GS. I had the motor apart and saw a small silver part and I am wondering if that is the cap.
Post# 1160909 , Reply# 1   10/2/2022 at 12:39 (561 days old) by cfz2882 (Belle Fourche,SD)
that part is the thermal protector.IIRC,no capacitor is used on these GEs.If you locate a wiring diagram for the washer-don't remember if there is one in the machine,could do a couple ohm checks to see if all motor circuits are intact.
