Thread Number: 91581
/ Tag: Vintage Dryers
Help me fix this Creda Dryer |
Post# 1161033 , Reply# 1   10/3/2022 at 07:32 (569 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I would start by taking the top off and start checking wire connections, door switch timer control connections at the junction block where the cord connects to the wiring harness etc.
Compact dryers like this have problems with wiring connections often times timer could be bad of course but that’s easy to check or bypass to see if that’s the problem. Good luck with the dryer and I hope things improve with your dad. John L |
Post# 1161036 , Reply# 2   10/3/2022 at 10:00 (569 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
As I’ve tried and doing the three screws at the back and pushing forward to see if that would release any clips, but that didn’t work do you have any ideas? |
Post# 1161039 , Reply# 3   10/3/2022 at 11:16 (569 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1161078 , Reply# 4   10/3/2022 at 18:14 (569 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
And I think it might be the door switch as I can hear it Click but it doesn’t then start, and I’ll check whether cable goes into the dryer which is behind the dust cover for the heating element |
Post# 1161096 , Reply# 5   10/4/2022 at 02:54 (568 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
But the idler pulley appears to Squeak until it gets up to speed, it’s not allowed Squeak is just something that happens for about 30 seconds and then it’s good |
Post# 1161098 , Reply# 6   10/4/2022 at 02:55 (568 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
Post# 1161101 , Reply# 7   10/4/2022 at 05:19 (568 days old) by Chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 1161109 , Reply# 8   10/4/2022 at 08:12 (568 days old) by gizmo (Victoria, Australia)   |   | |
The dryer underneath is an Aussie Hoover dryer, I believe (no proof but they are very similar) based on a Fisher and Paykel design from NZ. |
