Thread Number: 91661
Maytag DE606 from Dec 1967 in Coppertone |
Post# 1161800 , Reply# 1   10/16/2022 at 12:48 (556 days old) by pulltostart (Mobile, AL)   |   | |
Post# 1161801 , Reply# 2   10/16/2022 at 13:12 (556 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1161802 , Reply# 3   10/16/2022 at 13:36 (556 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1161803 , Reply# 4   10/16/2022 at 13:42 (556 days old) by qsd-dan (West)   |   | |
Beautiful set, they were very well taken care of!
If the agitator is original to the washer, it was made somewhere between Nov 1967 and December 1968. Probably closer to Nov 1967-Feb 1968. If you shoot us a photo of the model placards on the back of the washer and inside the door of the dryer, we can decode the dates for you. |
Post# 1161808 , Reply# 5   10/16/2022 at 14:32 (556 days old) by Good-Shepherd (New Jersey)   |   | |
Nice score. Maytag shaded coppertone set in excellent condition are rare as hens teeth these days. |
Post# 1161813 , Reply# 7   10/16/2022 at 16:27 (556 days old) by lilmamabigdrama (Colchester, CT)   |   | |
Here are the serial numbers for both! |
Post# 1161814 , Reply# 8   10/16/2022 at 16:33 (556 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1161821 , Reply# 9   10/16/2022 at 19:15 (556 days old) by Good-Shepherd (New Jersey)   |   | |
Did you try removing the agitator? Should pull straight up, hopefully without a major battle. |
Post# 1161845 , Reply# 11   10/17/2022 at 10:25 (555 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 1161850 , Reply# 12   10/17/2022 at 11:52 (555 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1161855 , Reply# 13   10/17/2022 at 14:36 (555 days old) by Good-Shepherd (New Jersey)   |   | |
If the agitator comes off without a battle put some silicone grease or vaseline on the splines/ stop ring and breath a sigh of relief. Sometime the agitators on older models with the stop ring are stuck tight. |
Post# 1161885 , Reply# 14   10/18/2022 at 04:05 (555 days old) by Easyspindry (Winston-Salem, NC)   |   | |
You're gonna love 'em!!! Jerry Gay |
Post# 1161959 , Reply# 15   10/18/2022 at 20:05 (554 days old) by electronicontrl (Grand Rapids, MI)   |   | |
Post# 1161987 , Reply# 16   10/19/2022 at 08:58 (553 days old) by appnut (TX)   |   | |
Abigail I'm speeechless. CONGRATULATIONS. I had to do a double-take when I looked at the pictures as its been a while since I've seen a center dial Tag that hadn't the Perm Press cycle on the timer. I was just thinking about a friend of my mom's getting her brand new 606 washer August of 1966 or 1967 recenty. I got to go over and see the new washer a day or so after it had been installed and she saved a bunch of laundry for me to do. I was reminiscing what the new washer smell was for that very washer.
I also had a former co-worker back in the early 1980s who was nearing retirement age. He and his wife got that same set in coppertone so it would be th washre to serve them during their retirement years. When I walked through their laundry room, I had to stop and stare at just how stunning they were even then. Nick commented that it as the best washer & dryer they'd ever had and his wife knew just how to use them, he felt their laundry was perfect. That set looks like it is brand new. Ditch cold water washes as a general rule of thumb, only very special when needed instances. Wash predominantly in warm or hot. Especially now that it's fall/winter and you'e in CT. Also use top-knotch powdered detergent such as Tide. Not liquid detergent. If you live in an area that has hard water, get some STPP (sodium tri poly phosphates (phosphates) from Amazon and add a couple of tablespoons per wash load. Also, the Perm Press cycle on the dryer was recommended for loads that are hard to dry, such as jeans, sweats, think bulky towels, blankets. That cycle has a higher temperature set point to get the wrinkles out of perm press fabrics as they were produced back then. The Perm Press cycle also has a longer cool down phase than regular. The cooldown is thermostatically controlled and is only about 3-4 miutes on regular and 7-10 minutes on Perm Press. If you have some items that you wish to be slightly less dried than normal, then use Damp Dry cycle and when it turns off, use Air Fluff to let the load cool down. Back then, Maytag dryeres had Air Fluff, low, and regular temperatures. Their Electronic Control dryers dried at low temperature so that it was deemed an all-fabric dryer. I had a Maytag dryer for 27 years and I used the Perm Press cycle 98% of the time. |
Post# 1161989 , Reply# 17   10/19/2022 at 09:19 (553 days old) by peteski50 (New York)   |   | |
Post# 1161992 , Reply# 18   10/19/2022 at 09:30 (553 days old) by Washerlover (The Big Island, Hawai’i)   |   | |
Post# 1162003 , Reply# 19   10/19/2022 at 11:59 (553 days old) by bajaespuma (Connecticut)   |   | |
These are classics; enjoy them in good health!
Post# 1162012 , Reply# 20   10/19/2022 at 15:21 (553 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1162028 , Reply# 21   10/19/2022 at 19:18 (553 days old) by thatwasherguy (Kentucky)   |   | |
Those look like beautiful low-mileage machines. With just a little bit of preventative maintenance (damper pad lubrication, mainly), they should last for years to come. My 1978 Maytag set had about a million miles on them, and needed a lot more work than these look like they will. Center dial Maytags are my favorite machines of all time, so I am particularly happy to see someone who appreciates them as much as I do.
Thatwasherguy. |
Post# 1162226 , Reply# 22   10/22/2022 at 00:58 (551 days old) by Hippiedoll ( arizona )   |   | |
