Thread Number: 91838
/ Tag: Vintage Dishwashers
Ancient DishDrawer Failure |
Post# 1163656   11/11/2022 at 18:15 (530 days old) by DADoES (TX, U.S. of A.)   |   | |
My DishDrawer has officially become vintage per AW standards by the serial number of November 2002 (UUM756561), although it's less per the purchase date. The lower drawer became effectively unusable probably a year ago. It'd beep and go into pause with the display flashing within a few mins of starting a cycle. No fault code. Pressing Start after a couple/few mins wait would have it continue for a couple/few mins then pause again, or the paused cycle would abort after a time-out if I didn't notice the reminder beeps. I figured the IR emitter or pick-up for the drawer-closed sensor had become erratic. Easy enough to get around the situation by using the upper drawer, until it exhibited the same problem a few weeks ago. So, time to address the problem. Lower drawer first. There are reports of the solder loosening on the IR components on the board, fixable by remelting. However, I found that the problem was that a couple of the mounting clips for the control board housing had broken and the module had shifted from proper position, causing misalignment of the IR beam. Attempting to secure the module caused another clip to break and the whole thing dropped down. The plastic F&P used for the board housing apparently doesn't age well. I devised an alternate method of supporting and securing the module. Examination of the upper drawer found that the same problem had occurred. Two clips had broken and the IR emitter and pick-up were misaligned with the prism light pipes. I again devised a method of anchoring the module into proper position. Good to go for another 20 years! |
Post# 1163660 , Reply# 1   11/11/2022 at 18:29 (530 days old) by qsd-dan (West)   |   | |
Post# 1163663 , Reply# 2   11/11/2022 at 19:00 (530 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1163664 , Reply# 3   11/11/2022 at 19:27 (530 days old) by appnut (TX)   |   | |
Post# 1163666 , Reply# 4   11/11/2022 at 20:47 (530 days old) by Tomturbomatic (Beltsville, MD)   |   | |
YAY Glenn! |
Post# 1163684 , Reply# 5   11/12/2022 at 02:53 (530 days old) by bradfordwhite (central U.S.)   |   | |
Post# 1163686 , Reply# 6   11/12/2022 at 04:26 (530 days old) by ozzie908 (Lincoln UK)   |   | |
I sadly have to report that both the newer sets I had have bitten the dust by blowing themselves up and I mean literally ..... The latest one decided to leak and it dripped onto the circuit board which they had moved to the back of the machine to prevent such incidents???? The previous one also went bang and burnt its way through the insulation inside the door which caused a lot of smoke. So I was without a dishwasher so Facebook marketplace to the rescue I bought a Bosch ordinary model and have remodelled the gap to accommodate it and so no more dishdrawers for me :( I now have spares for quite a few models if anyone needs anything.
Post# 1163691 , Reply# 7   11/12/2022 at 10:07 (530 days old) by DADoES (TX, U.S. of A.)   |   | |
BradfordWhite, DishDrawer development began in 1987. They were introduced to the market in 1997. Mine is model DD603. 601 and 602 series preceeded DD603. Yes, my electronic-control appliances are powered continuously ... refrigerator, range, dishwasher, microwave, washer, dryer, HVAC ... and TVs, DVD, computers, cable modem, WiFi router, clocks. |
Post# 1188131 , Reply# 8   8/21/2023 at 20:54 (247 days old) by DADoES (TX, U.S. of A.)   |   | |
My DishDrawer is 20yo today by purchase date.
Post# 1188136 , Reply# 9   8/21/2023 at 21:31 (247 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1188153 , Reply# 10   8/22/2023 at 02:24 (247 days old) by ozzie908 (Lincoln UK)   |   | |
