Thread Number: 91921
/ Tag: Vintage Dryers
Are older model dryers a potential health hazard |
Post# 1164626 , Reply# 1   11/23/2022 at 07:42 (513 days old) by Adam-aussie-vac (Canberra ACT)   |   | |
And will never contain asbestos, I don’t think all that much has changed in the way how manufacturers make dryer belts |
Post# 1164629 , Reply# 2   11/23/2022 at 08:22 (513 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
Asbestos belts, no, but it is likely that there are asbestos panels/linings in some of the heated areas. Non-friable (intact) asbestos isn't a health danger, so unless things are crumbling you should be fine. Taking-apart and reassembling, though, does introduce a risk if you're monkeying around with the asbestos-coated fittings.
Post# 1164634 , Reply# 3   11/23/2022 at 09:15 (513 days old) by Maytag85 (Sean A806)   |   | |
Since it’s more dry in the fall and winter months, won’t really pose a problem since the air is more dry. Would only pose a problem in the spring and winter months where there’s more humidity in the air. The main reason why dryers are vented to the outside is because of the lint and humidity they produce, not because of carbon monoxide etc. Asbestos more than likely would be around the area of the heating element, don’t think dryer belts would contain asbestos since most were reinforced with fiberglass, fabric, and steel cables in the belt around the drum setup.
Post# 1164701 , Reply# 4   11/23/2022 at 21:37 (512 days old) by LowEfficiency (Iowa)   |   | |
An unvented gas dryer would have the same set of health concerns as a gas range - It's a subject of much debate here on this forum, but there are some good articles and research out there describing the harmful combustion byproducts that are released into the air when cooking, and their related health effects... If the model dryer you have does use asbestos insulation, I'd personally call it and find something different. The combination of combustion byproducts, excess humidity, linting in a food prep area, and risk of insulation spread just doesn't seem worth it to me... |
Post# 1164716 , Reply# 5   11/24/2022 at 05:44 (512 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I don’t think any US dryers used any asbestos in them certainly not after 1980 and probably much earlier.
I did read that some drive belts at one time about 10 years ago. especially ones that came from Asia had a little bit of asbestos in them I imagine the amount would be so small has to be pretty insignificant. As far as length goes, just handling sorting folding and ironing laundry creates a lot of very find lint and there is some negative health effects from this cotton lint is a carcinogen. For these reasons I generally don’t think you should have it inside vented dryer but it’s probably not gonna kill anybody either. Using an exhaust fan in the room and keeping the room under negative pressure would go along way to reducing this dust buildup when doing laundry I guess if the dryer can’t be vented directly. As far as combustion products if you were using a gas dryer which of course is not common in Europe anyway, whenever you’re burning any fuel there are combustion products that are released most appliances that are fuel burning or vented directly outside the home. Gas ranges and unvented gas heaters are a special problem, good practice would insist on a good ventilation above a range and use it whenever the ranges of use even just for boiling water. Unvented gas clothes dryers of course would release some combustion products however it’s far less than a gas range, gas burners are notoriously bad and ovens are not very good either in this regard. it a gas clothes dryer the flame is normally burning in free air not touching any cold metal so you tend to get a more efficient combustion process but it’s still never perfect. John |
Post# 1164720 , Reply# 6   11/24/2022 at 06:12 (512 days old) by retro-man (- boston,ma)   |   | |
Just an observation, I don't see where op stated that this is a gas dryer. I was assuming that this is an electric dryer. Jon |
Post# 1164811 , Reply# 8   11/25/2022 at 06:47 (511 days old) by Chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hello and a warm welcome to Automatic Washer , is this the type of dryer you have ? , its a compact Creda and while design hasnt changed over the years, the components such as the heater cover plate is now coated so there will be no asbestos heat insulation pads like on much older dryers .
Great dryers with fast air flow, though it vents from the front you can get an adaptor plate and plastic hose to fit on the door and stick the hose through a window when in use. You can usually find these on ebay etc , these are certainly a lot quicker than condensor types which work much better in a cold room. Cheers, Mike |
Post# 1164922 , Reply# 9   11/26/2022 at 11:37 (509 days old) by statomatic (France)   |   | |
Health hazard will occurs when washing always at low temperatures, using crappy detergent & softeners and keep the machine closed after cycle.
On the photo a mucky Philips T12M860, the owner used only cold and 30°C cycles and way too much detergent. Got called for a clogged pump, that ended with a new pump, bearings replacement and steam disinfection of the whole machine.
