Thread Number: 92135
/ Tag: Vintage Dryers
Can someone please identify this Kenmore Dryer? |
Post# 1166945 , Reply# 1   12/18/2022 at 14:10 (491 days old) by Maytag85 (Sean A806)   |   | |
Post# 1166949 , Reply# 2   12/18/2022 at 14:31 (491 days old) by RP2813 (Sannazay)   |   | |
Post# 1166950 , Reply# 3   12/18/2022 at 14:32 (491 days old) by qsd-dan (West)   |   | |
Post# 1166962 , Reply# 4   12/18/2022 at 15:56 (491 days old) by DADoES (TX, U.S. of A.)   |   | |
Model/serial tag is affixed near the clothes loading port, visible when the door is open ... it has been removed if not there. Example:
Post# 1166978 , Reply# 5   12/18/2022 at 17:40 (491 days old) by Repairguy (Danbury, Texas)   |   | |
Post# 1166991 , Reply# 6   12/18/2022 at 19:45 (490 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Hello everyone,
Finally I have some downtime to post on here (it’s been a while). Great dryer! My Mom bought one of these in a set in December 1982. We retired it in 2018, still working. I put a WP rebuild kit in it around 2007, and later an element. There were four versions of this dryer starting in 1981, with the 110.861741x0. The model number I gave here is for white. There was also a 1982 model, 110.862741x0. That is the one we have. Both have the full width door, and all four are 70-series models. There were also 1983 and 1985 models, 110.863741x0 and 110.865741x0. The 83 and 85 models have the new door opening. I am not sure what the difference is between the 81 and 82 models, though the 81 may not have the lint alert whistle that the 82 does. The element is part number 4391960. Most any parts store or outlet should have it. I have a 1982 Gold matching washer that would make a nice mate to this dryer. Gordon |
Post# 1166998 , Reply# 8   12/18/2022 at 20:54 (490 days old) by Maytag85 (Sean A806)   |   | |
Pretty much all Whirlpool 29” dryers made after 1966 all have interchangeable parts since they all take the same rollers, drum belt, thermostats, and a few other parts. Though there are a few different style of heating elements since the the standard capacity 29” dryers have the element that slides out of the heating element plenum and the newer style have the heating element that separates from part of the plenum if that makes sense.
Post# 1167002 , Reply# 9   12/18/2022 at 21:59 (490 days old) by qsd-dan (West)   |   | |
Post# 1167003 , Reply# 10   12/18/2022 at 22:01 (490 days old) by Maytag85 (Sean A806)   |   | |
Post# 1167010 , Reply# 11   12/18/2022 at 22:16 (490 days old) by RP2813 (Sannazay)   |   | |
Post# 1167022 , Reply# 12   12/19/2022 at 03:50 (490 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1167026 , Reply# 13   12/19/2022 at 07:01 (490 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Yes, there is a lot of parts interchangeability on these great dryers. There’s also a lot of different parts. There’s seven different heating elements that are not interchangeable with each other. There’s a lot of slight variations that are interchangeable in some cases.
There are 4 Different Dr. belts used most are interchangeable, but one is not interchangeable Great to see a post from you Gordon . I hope you’re doing well. Check in sometime John. |
Post# 1167068 , Reply# 14   12/20/2022 at 00:18 (489 days old) by bradfordwhite (central U.S.)   |   | |
Super nice dryer. I hope it works good for you.
Have you seen the inside yet?
That one is probably #2 here from 1982 which I believe was the last year for the squared full-width door AND the first year for the newer script style.
Post# 1167175 , Reply# 15   12/21/2022 at 16:29 (488 days old) by chaskelljr2 (Washington, D. C.)   |   | |
Welcome Back Gordon… —Charles— |
Post# 1167624 , Reply# 16   12/27/2022 at 02:04 (482 days old) by 70series ( Connecticut.)   |   | |
Welcome Back Gordon! Great to see you posting again. |
