Thread Number: 10305
Maytag Dryer Model No.: GDE808 - Help |
Post# 189301 , Reply# 1   2/7/2007 at 18:42 (6,287 days old) by toggleswitch (New York City, NY)   |   | |
Is it DG808 or DE808 or as stated? Someone please correct me here, for me it's a stretch. This dryer sounds like it has electronic dry control. As such, moisture across the sensors allows a small electrical current to constantly discharge. As the clothng become dry the current is no longer discharged, therby building up in a capacitor until it is storng enough to trip a relay turning off the dryer. The amount of currnet the capactor holds dtermines the cycle and the amount of time until it trips from the "it's dry" signal /build-up of charge. So my guess is, there is an open circuit, or loose wire prenventing the neessary discharge through the sensors. (Have you tried gently washing them with a nearly dry cloth and mild soap, especially if you use dryer softener sheets?) Is the dryer properly grounded/earthed? Have you moved any connectors, changed the power flex cord, (or hard-wire cable)or added a rug under the machine? Are the rotary contacs and "brushes" ( I think this is near the filter) making contact such that the sensors are electrically coonected (continuity) to the contorller? If by control switch you mean the eletronic sensing controls, it is probably a good idea to have a spare one even if it does not solve the problem, as these are probably soon-to-be (if not already) NLA. Good luck. I'm curious myself to hear what is actually wrong with it. |
Post# 189316 , Reply# 2   2/7/2007 at 19:02 (6,287 days old) by toggleswitch (New York City, NY)   |   | |
