Thread Number: 1041
HELP-KENMORE EXPERTS-Free at last, but-------- |
Post# 54127 , Reply# 1   1/21/2005 at 15:49 (7,035 days old) by Unimatic1140 (Minneapolis)   |   | |
Should the outer tub be scrapped altogether? If not, Should I attempt to remove the outer tub to replace the old washers around the four attachment bolts, AND/ OR the center post gasket? Hi Steve, congrats on getting over your biggest hurdle, removing that #@&^%! spin basket. That is a pain, to say the least, in vintage WP/Kenmore washers, some brands are easier than others and the Whirlpool design is one of the worst for having stuck baskets. The big difference between repairing and restoration is with a repair you are simply trying to make the machine work again with minimal effort. With a restoration you are taking the time to prevent future problems, such as a new leak under a different bolt or seal six months from now. This allows you to use the washer quite often without having to go back in (hopefully) and do more work. Anyway, here is what I would do… No don’t scrap the outer tub. Do pull it and replace the rubber washers (available at a hardware store) under the bolts that hold the outer tub down to the baseplate. Most likely the leak is coming from the center post seal which is relatively common. Since it’s a 1959 model it should have the later rubber molded seal. These are still available from Whirlpool so you should have no problem getting one. When you install the new seal be sure to liberally coat the inside (side that faces the centerpost) with silicone to help seal around the rusted centerpost. As for the rusted centerpost itself, every one of these centerposts I have seen has been rusted. The bolt down Kenmore washer I had was so badly rusted that I scrapped the machine. The others I’ve always just left them alone, but I suppose you could sand it down and paint it with two part epoxy paint available at high end paint stores. |
Post# 54130 , Reply# 3   1/21/2005 at 16:11 (7,035 days old) by Goatfarmer (South Bend, home of Champions)   |   | |
Post# 54134 , Reply# 5   1/21/2005 at 18:11 (7,035 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Sounds like there is a consensus about what to do about the tub... If you do want to touch up the rusty spots, try this product I have linked, I used it on the 59 Frigidaire tub and it's amazing stuff! water can never penetrate it and it will adhere to anything without sanding!
CLICK HERE TO GO TO gansky1's LINK |
Post# 54142 , Reply# 7   1/21/2005 at 19:39 (7,035 days old) by Gyrafoam (Wytheville, VA)   |   | |
Greg, thanks for the information on the "POR-15". That sounds perfect for the job. I Just wanted something to keep this rust from getting any worse and this stuff sounds like just the ticket! -Steve |
Post# 54165 , Reply# 9   1/21/2005 at 22:44 (7,034 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 54234 , Reply# 12   1/22/2005 at 14:46 (7,034 days old) by Unimatic1140 (Minneapolis)   |   | |
I have to look and see if I have one of those parts Steve for the 1959 Kenmore. If you type the model # into the sears web site does it give you the hose part #? If it appears to be nice and pliable, I'm sure its fine and I wouldn't bother replacing it yet. As for the bearing, just like Fixerman said its quite a job and you do need special tools. See my 1957 Lady Kenmore restoration photos for pictures of the bearing tools and how to change them. |
Post# 54344 , Reply# 17   1/23/2005 at 13:53 (7,033 days old) by westytoploader ()   |   | |
Oops, link isn't working. On RepairClinic, in the "Find Parts" section, select "Kenmore," "Washing Machine", then type in 110.6015710 in the Model Number box. You should have a list of parts available for it. |
