Thread Number: 1142
The Wash & Wear Cycle |
Post# 55371   1/30/2005 at 23:01 (7,025 days old) by Unimatic1140 (Minneapolis)   |   | |
Well the new turquoise '64 Kenmore washer works fine except for the fact the pump is noisy and slow and needs to be replaced. The transmission was changed to a later splined version at some point and the spin tube and brake assembly was also changed to the post 1971 fast-brake version. I’m surprised with all that work that the machine still has its original 1964 aluminum pump. It was fun to use the Wash & Wear cycle, I haven’t seen this for over 20 years. During the cool down cycle the washer drains at low speed and when the water level switch is tripped back to the empty mode (about ½ drained) the washer stops and fills back up with cold water, then when the full water level is reached the washer drains ½ way again and the process is repeated. Our Kenmore from ‘68 would agitate on low speed during the refill process, but this machine simply fills. I’ve seen Whirlpool washers that would just fill without doing any low agitation too, so I’m sure they must have experimented with the cool down cycle throughout the years. Here are a few live shots of the Wash & Wear cycle and the results... CLICK HERE TO GO TO Unimatic1140's LINK |
Post# 55372 , Reply# 1   1/30/2005 at 23:50 (7,025 days old) by arrrooohhh (Sydney Australia)   |   | |
YAY! Looks like a real nifty little machine :) |
Post# 55373 , Reply# 2   1/31/2005 at 00:01 (7,025 days old) by glenn ()   |   | |
I have a 65 Kenmore, and I have always loved the Wash& Wear Cycle. It is a shame they did away with it. I believe it was a great kenmore feature. Great machine you have there. |
Post# 55403 , Reply# 4   1/31/2005 at 08:52 (7,025 days old) by Unimatic1140 (Minneapolis)   |   | |
I have no idea if those clothes were "perm press clothes" they don't use that term anymore. But my point was you can cool the clothes down, then spin them slowly or you can wash them in hot water and spin the at 1140. It doesn't matter if the clothes come out of the washer wrinkled, its how they come out of the dryer that counts. The dryer will remove 95% of the wrinkles of most clothes no matter how they were washed. I think the Wash & Wear and PP cycles had there place 35 years ago for people who hung clothes on the line, but if you are using a dryer (and do not overload it) its unecssary.
Post# 55408 , Reply# 5   1/31/2005 at 09:11 (7,025 days old) by Jmm63 (Denville, NJ)   |   | |
I remember our 69 Kenmore 800 had a cool P/P cycle too. It would wash at regular speed and then switch to slow speed for the last 4 minutes of wash time. Then it would drain 1/2 way, pause, then slow agitate and fill with cold water, drain again, spin with 4 spray rinses, and then fill for the final rinse. Water usage sure wasn't a concern back then! :)
Post# 55419 , Reply# 6   1/31/2005 at 09:37 (7,025 days old) by frigilux (The Minnesota Prairie)   |   | |
Our 1960 Model 80 Kenmore's Wash 'n' Wear cycle was a little different than yours, Uni. The Sturdy Wash 'n' Wear cycle provided 4 minutes of fast, then 4 minutes slow agitation. The wash water temp was called 'medium' (halfway between warm and hot) The cool-down portion filled and drained 4 times (a waste of water, frankly). Even after 4 fill/drains, the water at the opposite side of the tub from the fill tube was still warm, as there was no agitation to move the cooled water around. The Delicate Wash 'n' Wear cycle provided 4 minutes slow agitation and then the fill/drain cool-down. The wash water temp was warm. |
Post# 55459 , Reply# 10   1/31/2005 at 15:18 (7,024 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
There were two kinds of Permanent press, the treated fabric kind which was early and wore away over time and the woven synthetic kind which was usually polyester blended into a natural fiber in different ratios depending on who made it. Wrinkles were set when the clothes went into spin and were hot or warm. Also I was told in the day dirt would actually ahere on PP if the clothes were washed in hot water> When Mom bought her first set of PP sheets she thought she was "cooking with Gas"!! We were modern! But when i first tried them out and rolled over in bed i nearly about burned my knees off from the friction heating! HORRID STUFF! BURN IT!! Nothing was better for rinsing than running the WP on PP cycle, just be sure you unplugged the water meter first! Jet |
Post# 55471 , Reply# 11   1/31/2005 at 16:01 (7,024 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 55474 , Reply# 13   1/31/2005 at 16:04 (7,024 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Our sears 1960 model worked like roberts 64 it just filled with cold water. Our sears 1984 TOL agitated for 1 minute and drained,then spinned low speed Maytag 806 and 606 agitated for 1 minute but my 308 fills and then SD correct this as I get more info about vintage washer on this site from everbody than i could get anywhere else |
Post# 55483 , Reply# 14   1/31/2005 at 16:52 (7,024 days old) by DADoES (TX, U.S. of A.)   |   | |
Whirlpool's Knit Cycle, at least for a while, had a 1-stage cool down (one partial drain, refill, 2 mins agitate), while Perm Press had a 2-stage cool down. The replacement timer for our 1976 Supreme 80 had Prem Press reprogrammed with a 1-stage cool down. I think the extra space on the dial was used for a 4-min agitate instead of 2-min, and the drain period had an extra 2-min pause. Interesting that Knit on the replacement timer also still had the 1-stage cool down. My F&P GWL08 does a full drain, then cold refill and agitate. My IWL12 does the same, but the Creasables option on it *also* increases the water level for more 'float space' to the wash. |
Post# 55509 , Reply# 16   1/31/2005 at 19:55 (7,024 days old) by coldspot66 (Plymouth, Mass)   |   | |
Kenmore introduced a Wash'n Wear cycle in 1958 on the washer; prolly on TOL models, according to "Kenmore Firsts" in one of the 60's catalogs. |
Post# 55519 , Reply# 17   1/31/2005 at 21:28 (7,024 days old) by veg-o-matic (Baltimore, Hon!)   |   | |
I'm going to come out and admit it: I NEVER used the permanent press cycle. Well, maybe once, but since it didn't make any difference (other than taking longer), I stuck with Normal. Now Gentle, on the other hand, that's another story. Need that in a TL when you do sweaters and stuff. Never used it on my Frigidaire FL, though. Come to think of it, I only use the Normal cycle on the dishwasher, too. Guess I'm just a simple fella. veg, the simpleton |
Post# 55529 , Reply# 18   1/31/2005 at 22:54 (7,024 days old) by appnut (TX)   |   | |
Sears did a sort of transition that had both WW and PP names on the cycle for that use for a while. I also saw 1959/1960 alphabet Kenmore and a Model 70 that did the normal then gentle agitatino during the wash cycles for study & delicate wnw. then, it drained partially on high and filled iwth cold water and it was repeated 3-5 times. I had this reconfirmed as late as 1970 when visiting Dallas. Our 1964 Norge had a durable press button that filled with hot water. I had to let it fill with a warm water cycle and then push the DP button (3%) after filling. I used the PP cycle on our 1971 Kenmore 800 quite a bit. I used the PP cycle of did a manual cool down with all my hangable stuff since it was all washed on delicate. Meaning I always caught it as it was draing after the wash and when I heaerd the water level switch click, I'd stop, turn the dial around to 4 minute wash and fill with cold water. Since joining the club and aid by certain people, I don't do any of that any more. And I now even spin all this stuff out on normal spin speed. And it's rare I use a cold rinse anymore either since most of my stuff is wrinkle-free cotton. The dryer does it all. |
Post# 55534 , Reply# 19   12/31/2069 at 18:00 (19,839 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Most if not all European FL's that do "boil" washes have some sort of cool down phase before spinning. This prevents set in wrinkles. But wash water temp has to be brought down gradually to prevent textile shock. Some washers will drain the hot water from the tub and replace it with cold water in several batches. Others remove the hot water but have several fill/tumble/drain cycles where cold or warm water is added to gradually bring down temps. Personally believe items washed in hot or super hot water should be rinsed in warm with perhaps the final deep rinse in cool/cold. Remember to back in the days of laundry "soap", warm rinses were needed to get all the soap out of the laundry. Sudden drop in water temp would cause textile fibers to constrict and hold onto soap. Of course modern detergents do not suffer from this problem. Launderess-+ |
Post# 55562 , Reply# 21   2/1/2005 at 08:50 (7,024 days old) by frigilux (The Minnesota Prairie)   |   | |
Scott55405--- the 1960 Model 80 had one-touch multi-colored pushbuttons. There was no cycle dial. The rhythmic clickety-clacking sound it made as the cycle set up is what I miss most about it. I wish I still had the owners manual so we could scan it. It was a very cool machine. There was a hot-water saver toggle switch on the side, which reduced medium temp water to warm, and warm water to cold. It had the waterfall lint filter and a timed bleach/fabric softener dispenser, as well as a tub light. Oh, and a 100-decibel out-of-balance buzzer (at least it seemed that way). It was a machine that required quite a few service calls over the years (although I suspect my mom was having an affair with LeRoy, the serviceman) but it was pretty high-tech for it's day. |
Post# 55704 , Reply# 25   2/2/2005 at 09:02 (7,023 days old) by RE563 (Fort Worth, Texas)   |   | |
If you pull up "archive.org" and in the search bar type in "Whirlpool", this is a video about "wash N wear". Of course it feature the Whirlpool Imperial with a time line dial of that era. It's pretty cool to watch as they have a cut away machine going through the "Wash N Wear" cycle of the time, but none the less very similar to today's PP cycle. I have to agree with most of the post on this thread. With today's all cotton or mostly cotton fabric's of today the PP cycle is really obsoulete. Looking at today's washers, and Having an HE3 in my laundryroom, I have a cycle on mine called "normal/casual". It's really the PP cycle just re-named.
Post# 55713 , Reply# 26   2/2/2005 at 09:24 (7,023 days old) by agiflow ()   |   | |
That WP set on the "archives.org" is absolutely beautiful.That was another design they should have kept longer. |
