Thread Number: 11746
Frigidaire skinny mini, I think? |
Post# 209406   5/10/2007 at 14:55 (6,196 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Hi all. Today at the local reuse/recycle store I saw a Frigidaire washer dryer (vertically stacked and attached at the back). It had an odd looking agitator, I think I've seen a picture of a skinny mini agitator here, and it looks pretty much the same. They have a price of 110.00 Canadian dollars for it. So...are they fun to use? How much does that cute little tub hold? Are they easily fixable? Fill me with your knowledge and advice please! Guy |
Post# 209441 , Reply# 1   5/10/2007 at 17:19 (6,196 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 209452 , Reply# 2   5/10/2007 at 19:25 (6,195 days old) by golittlesport (California)   |   | |
Post# 209455 , Reply# 3   5/10/2007 at 19:40 (6,195 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 209463 , Reply# 4   5/10/2007 at 20:20 (6,195 days old) by appnut (TX)   |   | |
Post# 209464 , Reply# 5   5/10/2007 at 20:22 (6,195 days old) by westytoploader ()   |   | |
The Synchro-Swing Frigidaires are fun machines and have surprisingly good action. By all means grab it...it would have already been brought home if I saw one! |
Post# 209484 , Reply# 6   5/10/2007 at 21:42 (6,195 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 209518 , Reply# 7   5/11/2007 at 06:56 (6,195 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 209538 , Reply# 8   5/11/2007 at 09:37 (6,195 days old) by golittlesport (California)   |   | |
Post# 209570 , Reply# 9   5/11/2007 at 14:34 (6,195 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 209595 , Reply# 10   5/11/2007 at 17:47 (6,195 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
From the factory the 110v machines had a relay that turned off the heat in the dryer while the washer was agitating and spinning as a 110-120v line likely won't have enough amps to run both. You can wire the 220v model to 110v, but you won't be able to run the washer and dryer at the same time without blowing the fuse/breaker.
Post# 209615 , Reply# 11   5/11/2007 at 20:19 (6,194 days old) by toggleswitch (New York City, NY)   |   | |
~Can I wire the laundry center to operate on 110v? I only have one 220v circut in the laundry room. Or you could have a "power strip" made such that your one circuit has both this and the other item (dyrer?) plugged in. Of course you'd only be able to use one dryer at a time. One dryer and this washer at the same time (via the power strip) MAY work as well. |
