Is there anyway to increase the amount of water used in the wash cycle on the Kitchenaid Ensemble Superba washer? If the soak setting adds an additional 3 gallons of water, there must be some adjustment on the circuit board that controls how much water the machine will use on the regular wash setting. The machine simply does not add enough water to wash the clothes properly. This may be what the manufacturers believe is sufficient water to clean the clothes but if I add a few more gallons through the soap dispenser, the clothes come out much cleaner and freshener.
