Thread Number: 11893
amp tag |
Post# 211198   5/20/2007 at 17:37 (6,185 days old) by christfr (st louis mo)   |   | |
before it tear into this amp i wanted to ask... she is all orig and when i got the machine 2 years ago it ran fine just seemed a little slow on the agi. then she has sat for most of the last 2 years. so when i got the machine out today to use her she spins fine but the aig is so so so slow im not sure whats wrong.. could the oil be that thick in that trans ? the belt and tension on the motor seems fine to me?
Post# 211205 , Reply# 1   5/20/2007 at 18:43 (6,185 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Post# 211216 , Reply# 2   5/20/2007 at 19:06 (6,185 days old) by easyspindry (Winston-Salem, NC)   |   | |
Hey Chris. Beautiful machine. A model newer than the one I grew up with. I remember our Maytag not liking cold weather. Seems the agi would be slow until machine warmed up. Has it been in an unheated space? Jerry Gay |
Post# 211223 , Reply# 3   5/20/2007 at 19:56 (6,185 days old) by gyrafoam (Wytheville, VA)   |   | |
Well, could it be bad seals? Water making its way into the tranny turning oil into grease? |
Post# 211235 , Reply# 4   5/20/2007 at 20:09 (6,185 days old) by 48bencix (Sacramento CA)   |   | |
Chris, Are you using hot water? The way those are built, they only fill with hot or warm water and the water is very warm. The transmission is built on the bottom of the tub and the water will warm up the oil. Martin |
Post# 211259 , Reply# 5   5/20/2007 at 22:08 (6,185 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 211287 , Reply# 6   5/21/2007 at 06:06 (6,184 days old) by christfr (st louis mo)   |   | |
well i did find in the repair book a note about the clutch slipping. and since the kids are in the garage i did wait till it was warmer out but the water in the tub was cool not warm. so i think im gonna lay it over and check out the clutch first. i hate the thought of having to crack that trans. but i guess worse things have happened ha ha.. thanks for the advice :-)
Post# 211291 , Reply# 8   5/21/2007 at 06:48 (6,184 days old) by mayken4now (Panama City, Florida)   |   | |
Chris: Run the machine like others have said with hot water. Many of my machines (Maytag's) needed to have the transmission oil changed and cleaned out. They work like brand new once that task is done. It takes about 4 hours to do. Old oil turns to thick grease like substance and needs heated up before it gives in. Steve |
Post# 211323 , Reply# 9   5/21/2007 at 09:28 (6,184 days old) by christfr (st louis mo)   |   | |
Post# 211354 , Reply# 10   5/21/2007 at 14:14 (6,184 days old) by laundromat (Hilo, Hawaii)   |   | |
Hey Chris!, Congrats on the Maytag gem!from my experiences in the slow agitation,I have found that(especially as old as she is)dissasembling the trans,cleaning the gears and relubeing the entire trans after draining it and thoroughly cleaning all the parts,then relubing it and resealing it,replacing a new seal and reassembling the entire transmission.This not only quiets the unit down but also stops all MAJOR problems that may occur from the age of the washer and its sitting out of use for decades. |
Post# 211513 , Reply# 12   5/22/2007 at 06:27 (6,183 days old) by christfr (st louis mo)   |   | |
well yea the oil does get thicker and less free flowing as it ages. i still have to tilt her over and look at the clutch i sure hope the trans isnt leaking down its shaft like the 61 did. but it can all be re done.. when i had the 61 apart the oil in there had gotten rather thick but after fresh oil was in there it was like day and night diff. so i guess its time to tear another tag apart
Post# 213139 , Reply# 13   5/30/2007 at 06:26 (6,175 days old) by christfr (st louis mo)   |   | |
found my old service book for this baby and it says the trans is packed with some type of grease not oil..so im wonderin if i remove the trans and like half of the grease in there and top it off with trans oil shouldnt that sort of mix together and like let the trans move with more ease or will that cause an oil leak down the shaft?? or is there an o ring seal on the shaft like oh lets say my 61 tag?
