Thread Number: 12099
Frankenmore recirc pump not working |
Post# 214043 , Reply# 1   6/3/2007 at 17:27 (6,171 days old) by jasonl (Cookeville, TN)   |   | |
Should I change the pump or let it go like that? Thanks. |
Post# 214061 , Reply# 2   6/3/2007 at 18:31 (6,171 days old) by rickr (.)   |   | |
Post# 214122 , Reply# 3   6/3/2007 at 22:18 (6,171 days old) by coldspot66 (Plymouth, Mass)   |   | |
If it's the 4 port pump, the impeller might be loose/broken. Does the pump make any new noises? If it's the 3 port pump with the small recirculating port, it could be clogged. Hope this helps! |
Post# 214205 , Reply# 4   6/4/2007 at 06:42 (6,171 days old) by jasonl (Cookeville, TN)   |   | |
It's not making any new noises, just no water coming out of the waterfall. I will check the hose/pump when I get the chance this weekend. I won't run it until I get it fixed again. |
Post# 214449 , Reply# 5   6/5/2007 at 16:11 (6,169 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
