Thread Number: 12342
Leaning Tub |
Post# 216876   6/19/2007 at 02:11 (6,161 days old) by btjustice ()   |   | |
Is it normal for a new Whirlpool TL tub to lean forward and to the right? If not, is there an easy fix to correct this? The washer is level and doesn't rock. |
Post# 216890 , Reply# 1   6/19/2007 at 06:17 (6,161 days old) by laundryshark (Cedar Rapids, Iowa)   |   | |
Does manually shifting the tub to the center help or does it keep leaning to the front and right whenever you let go or after a typical wash? Otherwise, check with your dealer to see if something is amiss in your particular machine.--Laundry Shark |
Post# 216901 , Reply# 2   6/19/2007 at 08:24 (6,161 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
