Thread Number: 13099
Epic/Duet/Kenmore HE door hinge and catch action |
Post# 227415 , Reply# 1   8/3/2007 at 21:19 (6,122 days old) by pulsator (Saint Joseph, MI)   |   | |
Every Duet/Kenmore HE I have encountered does this, my guess is that it's just the plastic door itself flexing, it wouldn't do this if the door was made of METAL like a MIELE'S, but our Duet has been in heavy operation since January 1st, 2003 and the door has never given us any trouble, you get used to the door dropping after a while...
Post# 227424 , Reply# 2   8/3/2007 at 21:48 (6,122 days old) by dnastrau (Lords Valley, PA)   |   | |
... I am OK with it. I am going to look at the ones at the store to compare as well. The big Miele is beautiful, but I can't swing that much loot at this point. Thanks for the feedback Jamie. Andrew S. |
Post# 228065 , Reply# 3   8/6/2007 at 11:47 (6,120 days old) by rp2813 (Sannazay)   |   | |
I have the same complaint about my Duets, both washer and dryer. I tightened up the the latch component on the door, which was loose upon delivery, but that didn't change anything. When I was first interested in a Duet a few years ago, I decided I would wait until they had a better system for the latch with the hopes that by the time I was ready to buy, prices might come down. Well, that didn't happen and I ended up with the 1st generation Duets which were an offer I couldn't refuse on clearance. I'm used to it now but am careful of both the latching mechanism as well as the hinge. The dryer is even worse than the washer, IMO. My old center dial Maytag used a simple magnetic "latch" for the door. The Duet has prongs top & bottom that require the user to really push on the door to make sure it's securely closed, and I don't like the protruding parts associated with this system. It strikes me as latching overkill. It appears your Epic has the same door design as my Duet. I saw that the top of the washer door is chopped off to clear the detergent dispenser, just like mine is. The new Duet design doesn't have the chopped off door. Maybe the latching has improved on those also. I haven't checked them out. I've decided that the rather crude latching arrangement is a small tradeoff for all of the attributes about my Duet washer that make it far superior to the top loader it replaced. Hope you are enjoying your Epic despite its less than desirable latching mechanism. |
