Thread Number: 14000
Maytag AMP Motor Needed HELP !!! |
Post# 240473 , Reply# 1   10/5/2007 at 09:02 (6,048 days old) by northwesty (Renton, WA)   |   | |
hasn't anyone retrofitted a newer motor into one of these older machines? Or was there a big design change? Hope someone has some advice. |
Post# 240477 , Reply# 2   10/5/2007 at 09:55 (6,047 days old) by swestoyz (Cedar Falls, IA)   |   | |
John, I am not sure on all the specifics on the AMP motor, but I do know that it was a cradle motor, and I also assumed that it was 1/3 HP 1725 RPM unit. If someone out there could confirm the motor diameter and shaft length/diameter (assumed 1/2in dia, or 48Y frame) on their unit, we could see if this match I found at work would fit for an AMP (it could be wired for CW rotation only). CLICK HERE TO GO TO swestoyz's LINK |
