Thread Number: 15025
Fisher & Paykel AquaSmart washer without LCD screen. |
Post# 254420 , Reply# 1   12/15/2007 at 23:53 (5,976 days old) by andrewinorlando ()   |   | |
There is a matching dryer for that machine...they have them at Lowe's. It's a top load dryer, still called the AeroSmart, identical in design to the washer. That washer is the impeller style machine, no agitator. |
Post# 254456 , Reply# 2   12/16/2007 at 06:58 (5,976 days old) by funguy10 ()   |   | |
I know the washer is impeller-style. It is an All-HE Top-Loader. Also, do you have a link to the matching dryer on the Fisher & Paykel website? |
Post# 254487 , Reply# 3   12/16/2007 at 10:38 (5,976 days old) by jons1077 (Vancouver, Washington, USA)   |   | |
Post# 254542 , Reply# 4   12/16/2007 at 16:24 (5,976 days old) by appnut (TX)   |   | |
Post# 254658 , Reply# 5   12/17/2007 at 08:01 (5,975 days old) by andrewinorlando ()   |   | |
The matching dryer (without the LCD panel) isn't available yet, so its matching dryer right now is the one with the LCD panel. I gather the other machine is coming very shortly. |
Post# 254733 , Reply# 6   12/17/2007 at 14:57 (5,975 days old) by dadoes (TX, U.S. of A.)   |   | |
Jonathan, the lock mechanism is a hook set on a pivot. The lid tab presses on the lower "foot" of it and the hook pivots forward to engage in the lid tab. To trick the mechanism, insert a slim object such as a table knife or spoon handle, into the slot at an angle, aiming at the bottom of the hook and hold it down. Once the locking solenoid triggers, it'll stay down. Aiming properly is a bit tricky, the object will tend to block the hook from moving forward. I cut a hole in an old credit card to approximate the lid tab. The card is a little on the flimsy side but works well-enough. |
