Thread Number: 15296
Frigidaire Affinity Front Loader |
Post# 257731 , Reply# 1   1/4/2008 at 19:53 (5,961 days old) by toggleswitch (New York City, NY)   |   | |
Post# 257738 , Reply# 2   1/4/2008 at 20:29 (5,961 days old) by appnut (TX)   |   | |
Post# 257765 , Reply# 3   1/4/2008 at 23:09 (5,961 days old) by laundromat (Hilo, Hawaii)   |   | |
My original Frigidaire front loader(made by Frigidaire for GE the Profile series)got all my whites white.My socks are 95% cotton not accrilic.When I had the accrilic ones,I had the same problem. They never got white especialy the bottom.I use the new Clorox "syrup" type chlorine bleach(HE)every other wash.I currently have the L.G.front loading washer.The one with the raised control panel in the back.It uses less water and does a great job getting clothes clean.It spins 1200 rpms.I only had a no spin problem when I washed a pull over shirt by itself.
Post# 257770 , Reply# 4   1/4/2008 at 23:35 (5,961 days old) by pulsator (Saint Joseph, MI)   |   | |
I had a similar experience with my aunt's new Kenmore He2 washer. It used almost NO water, and it has the worst rinsing results I've ever seen in my entire life!!! I was washing 2 tablecothes that had gotten pop spilled all over them, the machine wasn't even turning them over! The tableclothes were just bobbing up and down, not a soap bubble or drop of water in site. It didn't even distribute the load after the wash to get out a tiny bit of water, it drained then started filling for the rinse. It used a bit more water in the rinse, of course, then the thing foamed up like no other! It drained out that rinse water then filled again without spinning for the final rinse, same thing, suds halfway up the window! Finally, it proceeded to drain the final rinse out and ramp up to speed, I had to rinse the things 4 more times before the water went clear, and I used an 1/8 inch of HE liquid detergent! Finally, after the thing was done, I took the tablecothes out and found the stains still there! AGH!!!!!!
Post# 257825 , Reply# 6   1/5/2008 at 08:01 (5,961 days old) by decodriveboy (FL, US)   |   | |
I believe the Affinitys can be modified. I have a Frig (not that model) and it works/cleans great since I did an adjustment. |
Post# 257857 , Reply# 7   1/5/2008 at 11:14 (5,961 days old) by drhardee ( Columbia, SC)   |   | |
Here's a link to the PDF from Sears describing the units - I wish they got hotter on the sanitary cycle like the 170 F Bosch unit does!
CLICK HERE TO GO TO drhardee's LINK |
Post# 257946 , Reply# 11   1/5/2008 at 18:16 (5,960 days old) by westyslantfront ()   |   | |
Hi Bruce. I am sorry that you did not received an acknowledgement of your gift. In my opinion, it is very sad that you did not receive an outward sign of gratitude by the organization. Ross |
