Thread Number: 15444
New Top Loaders - how can you see the wash action? |
Post# 259992 , Reply# 1   1/15/2008 at 10:43 (5,945 days old) by unimatic1140 (Minneapolis)   |   | |
Well many of the washers now are using strong Magnets in the lids. I have the original GE Harmony. In order to trip the lid switch you have to take a strong magnet (not a like a fridge magnet, stronger) that you can get at Radio Shack and place it just to the lower left of the bleach dispenser bezel.
Post# 260019 , Reply# 2   1/15/2008 at 12:57 (5,945 days old) by dadoes (TX, U.S. of A.)   |   | |
Post# 260042 , Reply# 4   1/15/2008 at 14:38 (5,945 days old) by dadoes (TX, U.S. of A.)   |   | |
Yes, that is the magnet location on GE. Look for signs like that, protrusions or insets on the lid, to indicate where is the magnet. The reed switch it activates would be located adjacent on/under the machine's top when the lid is closed, that is where the magnet would be placed. Most any lid switch can be tricked or bypassed, just a matter of figuring out how. One of my Calypsos, which has the lid-hinge switch, I wired a Toggleswitch® across the circuit. When in the On position, the machine acts as if the lid switch is triggered. In the Off position the lid switch works normally. My F&P GWL08 has the magnetic-type lid switch, simple matter of placing a magnet on the top at the right position. My F&P IWL12 has a locking lid (only during spin). I figured out how to trick it easily enough, cut a hole in an old credit card to approximate the shape of the lid-lock tab to make it easier. |
Post# 260048 , Reply# 5   1/15/2008 at 14:48 (5,945 days old) by toggleswitch (New York City, NY)   |   | |
~One of my Calypsos, which has the lid-hinge switch, I wired a Toggleswitch® across the circuit. When in the On position, the machine acts as if the lid switch is triggered. In the Off position the lid switch works normally. I was just about to post that it's time I did this with my newer GE washer. While I'm in there poking around, I'm gonna add a momentary contact switch for spray rinses. Then when I get some confidence up, I'll devise a relay and timer to add automatic spray rinses once the pump motor has been on for a pre-defined period of time! |
Post# 260057 , Reply# 6   1/15/2008 at 15:11 (5,945 days old) by funguy10 ()   |   | |
How do you disable the lid lock on the newer GE Harmony with the glass lid and the HydroHeater? How do you disable it on the Maytag Neptune TL with the 2 rotating discs? I'm just curious. |
Post# 260410 , Reply# 9   1/17/2008 at 16:45 (5,943 days old) by washabear (Maryland)   |   | |
I just tried the suggestion above of unscrewing the hinge on my new Whirlpool. It works. It's an easy workaround that allows you to watch. Thanks. |
Post# 260545 , Reply# 10   1/18/2008 at 11:22 (5,942 days old) by washerman8 ()   |   | |
Ryanm, The SQ switch is located in the right back corner of the tub's opening. You have to pull the tub up a little, reach back and press the switch up to activate it. |
Post# 260601 , Reply# 11   1/18/2008 at 17:19 (5,942 days old) by mrb627 (Buford, GA)   |   | |
I believe that you can access the lid switch over the control panel behind the timer. There is usually a hold in the cabinet top where something can be passed to depress the lid switch. Of course, I used a 3 foot bungee cord between the underside of the rear down by the feet up to the lever under the top. Always depressed. And in the event of an unbalanced load, simply lift up on the bungee cord to reset switch. MRB |
