Thread Number: 15568
my new washer |
Post# 261752   1/26/2008 at 07:35 (5,935 days old) by hooverzodiac12 (Melbourne, Australia)   |   | |
Post# 262130 , Reply# 2   1/29/2008 at 04:05 (5,932 days old) by timon90 (Norway)   |   | |
I think you should buy it! I'm very pleased with my Asko appliances. I have the 20003 washer from 1993 and 7704 dryer form 1994. And to Gizmo: You get the door hinges as a repair set. The hinges on my 20003 is original, and still like new. Smooth and nice, even on 1600rpm. Only the doorlock rattles a bit on mine. I've replaced the drum, bearings, sealings, and the recirkulation hose ca 1 and 1/2 year ago. I also have repaired the electronic card once, but that was my fault. I broke of a component on the card. But I fixed it again;) |
Post# 262131 , Reply# 3   1/29/2008 at 04:07 (5,932 days old) by timon90 (Norway)   |   | |
Post# 262133 , Reply# 4   1/29/2008 at 04:20 (5,932 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
I`ve had my set 6yrs now and love them, easy to use yet all variables covered, Variable Spin from 400 through to 1600, Variable Temp from cold/30d through to 95d nr boiling, jet flush dispenser clears powder & additives, dispenser smooth sided for easy flush clean...Solid Door but you need to get used to closing it a quick flick closes it, if you press it you move/push the tub/shocks a bit.Super Rinse for intensive rinse, High Water Level on wash & rinse if needed, Pre Wash & Soak progs also....its about the only machine that you will find badged for commercial use as well, Electrolux, Nyborg & Primus etc....so thats sells it as well...
Post# 262140 , Reply# 5   1/29/2008 at 06:32 (5,932 days old) by toggleswitch (New York City, NY)   |   | |
Post# 262268 , Reply# 6   1/30/2008 at 09:41 (5,930 days old) by laundromat (Hilo, Hawaii)   |   | |
I had 3 sets when I lived in Fla.They were great and I sent one to Debra in Atlanta,GA and another one to Joe in Fla.Both of them are still in use.The set I kept is in storage now.I am using my L.G.and have a nice Whirlpool Electric dryer I got at the Goodwill Store for $15.It's a "Supreme"model with the sensor and interior light.
