Thread Number: 16339
How big is yours? Compare your drum size (FL only) |
Post# 271878 , Reply# 2   3/24/2008 at 14:28 (5,889 days old) by brisnat81 (Brisbane Australia)   |   | |
My 2006 model Miele W2888 5.5kg Machine has a drum that is 31cm deep and radius of 23.5cm. This gives, 23.5*23.5*3.14*31 = 53756.015 ccm or 54L That is roughly 9.8L per KG. |
Post# 271883 , Reply# 3   3/24/2008 at 15:12 (5,889 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 271974 , Reply# 5   3/25/2008 at 05:53 (5,888 days old) by toggleswitch (New York City, NY)   |   | |
Post# 271981 , Reply# 6   3/25/2008 at 07:14 (5,888 days old) by mrx ()   |   | |
Drum internal dimensions: Radius = 24.5cm Depth of drum to rim to flat part of back = 37cm Volume in Litres : 69.77 Litres. Rated volume = 8kg 8.72 KG of laundry per Litre capacity. |
Post# 271982 , Reply# 7   3/25/2008 at 07:15 (5,888 days old) by mrx ()   |   | |
Sorry should have read : 8.72 L per KG !! |
Post# 272034 , Reply# 10   3/25/2008 at 11:38 (5,888 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
The history behind the 3.5 cubic feet rating of the frigidaire frontloaders is a bit different. It's the capacity in comparison to a traditional toploader including the space that an agitator takes. This is pure theoretical and has nothing to do with the real measures of the machine. If you measure the size of the drum please measure the drum only and not the space in the rubber ring, that is not supposed to be used for tumbling the laundry. Ideally is 10L per KG laundry. If it's much lower than that you will possibly never fit that amount of laundry in your machine. |
Post# 272036 , Reply# 11   3/25/2008 at 11:47 (5,888 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
I overlooked the question about the big machines sold in Europe. The übersized Miele is not sold on this side of the pond. LG sells steamwashers here that have an 8KG capacity. In the past they sold the big frontloader with the back controls here and that one was rated for 10KG. Bosch rates it's Logixx10 as a 10KG machine but it only has a 88 litres drum which is also tilted. So that is 8.8L per KG. |
Post# 272040 , Reply# 12   3/25/2008 at 11:53 (5,888 days old) by lavamat78800 ()   |   | |
Bauknecht also sells a washer in Germany that holds 12 kg!! |
Post# 272054 , Reply# 13   3/25/2008 at 13:47 (5,888 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 272065 , Reply# 14   3/25/2008 at 14:51 (5,888 days old) by westyslantfront ()   |   | |
I have a Fridgemore by Electrolux which is 3.2 cubic feet. It is a great machine once I adjusted the water level control to allow a proper amount of water in the tub. Ross |
