Thread Number: 16411
Kenmore Electronic Washer |
Post# 272577   3/28/2008 at 12:33 (5,872 days old) by cleanteamofny ((Monroe, New York)   |   | |
My washer is throwing a hissy fit and I really need your help on this one. On the right side of the control panel there are two main control boards, but in reality there are a total of four for the whole control board. So which one do I replace? Here's the problem, for years the off/stop button has not work, but the machine still functions, but when steam from the hot water tends to short the board out when used. I'm ready to replace the board(s) but not sure which one to replace. Here is the link to my Kenmore Electronic 90 Series washer on Sears Parts.com 110.26955690 (Part number 17) Relay Board #3407099 (part number 23B) Key Switch #3407130 |
Post# 272578 , Reply# 1   3/28/2008 at 12:36 (5,872 days old) by cleanteamofny ((Monroe, New York)   |   | |
Post# 272607 , Reply# 2   3/28/2008 at 16:08 (5,872 days old) by coldspot66 (Plymouth, Mass)   |   | |
What are the symptoms? Can you key anything in? Can you start a cycle? |
Post# 272657 , Reply# 4   3/28/2008 at 19:02 (5,872 days old) by cleanteamofny ((Monroe, New York)   |   | |
John and Emilio, Thanks for the quick response! Right know thew washer is working fine without the stop button. Stop button never shut the machine off once it is turned on. At the time when the trouble began, I just hit per say *regular wash* or any other cycle, then hit start, the machine just shut off completely. Even when I do the diagnostic test, I hit any cycle then hit start, the machine will shut off. I just want to get this resolved soon. Larry |
