Thread Number: 16492
Maytag A502 washer |
Post# 273602 , Reply# 1   4/3/2008 at 14:18 (5,878 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 273634 , Reply# 2   4/3/2008 at 19:02 (5,878 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 273638 , Reply# 3   4/3/2008 at 19:31 (5,878 days old) by suzena ()   |   | |
Hi everyone! Thanks for the interest! I'll check with my mother-in-law about an "adoption fee". I'll try to post some photos in the next day or so. |
Post# 273819 , Reply# 4   4/4/2008 at 20:26 (5,877 days old) by volvoguy87 (Cincinnati, OH)   |   | |
The problem with the pump may be a very simple fix. This model Maytag washer has 2 drive belts on the bottom. One drives the pump (located in the front right corner of the machine) and the other drives the transmission (in the center of the machine). If the belt driving the pump has broken, it is fast, simple, and cheap to replace. To replace Maytag Belts: 1. Unplug the washer and turn off the water valves for safety. 2. Pull the washer out toward you. 3. Tilt the washer back so you can access the bottom (it does not need to lie on its back). 4. The motor is in the front left corner on a spring-loaded sliding mount. By tilting the machine back, the motor slides, releasing tension on the belts. 5. Remove the old belts by sliding them off of their pulleys. 6. Obtain new MAYTAG brand belts (about $23.00). Use only genuine MAYTAG brand belts because they are designed to slip and act as a clutch. If you use generic belts, the motor will overheat and stop, usually when starting the spin cycle. 7. Put new belts on their pulleys. 8. Put the washer back in position and make sure it is level (the feet screw in and out to adjust the level). The pump rarely fails on these washers. If it does fail, it can be replaced without too much difficulty. Thanks for posting, we like saving old appliances from retirement. Dave |
Post# 273823 , Reply# 5   4/4/2008 at 20:51 (5,877 days old) by queeny77 (BERWYN, ILLINOIS)   |   | |
Post# 273859 , Reply# 7   4/5/2008 at 06:10 (5,877 days old) by goatfarmer (South Bend, home of Champions)   |   | |
